Hi gang,
Can anyone point me in the direction of some add-ons that might help me to learn IML?
Thanks!
Any add-ons showing how to use IML?
sephult
I have one coming that allows you to drag and drop your modules to link and create them.
There is information on the Wiki page as well to help guide and direct, also looking in the resourcestemplates folder there are the template IML files you can reference to create your own.
-s
-s
shawnb
I have a patch that writes itself!
Conway's Game of Life....
http://www.sensomusic.org/forums/viewtopic.php?id=4929
Any questions, let me know,
