Probability drum machine
tanabarbier
Unread post by tanabarbier » 09 Jan 2013, 20:28
Hi everybody,
this is a simple toy but it is fun! It is a 4 elements drum machine, for each one you can set the probability of the element being played at each step along with its velocity.
Here two pictures:
They are two preset managers, one for the patterns and one for the drum kits.
Hi hat and cymbals are using a random sample mode, to add a bit of life.
I hope some people will have fun with it, have a good day!
Unread post by nay-seven » 09 Jan 2013, 23:21
cool
thanks to share
Unread post by grego mondo » 10 Jan 2013, 12:07
looks great !!
I'll test it week back home !!
thanks
GDLive
Unread post by GDLive » 12 Jan 2013, 11:01
thanks to share ! I planned to build one, not needed yet !! :)
GDLive
Unread post by GDLive » 12 Jan 2013, 11:20
I play with it since 30 min, nice work !
noise2sine
Unread post by noise2sine » 14 Jan 2013, 10:16
Yeah excellent work ! simple and very powerfull, making very nice groove using 21/8 time signature !
thanks again to share
tanabarbier
Unread post by tanabarbier » 14 Jan 2013, 16:53
Thanks to everyone who tried it!
I pushed it a bit further with four sequences by element and a probability to use the other three from bar to bar (you like from time to time but bar quantized) and a swing, to make it even more "human". Should I update it?
The one thing that I don't like with this change is that the pop up fills my whole screen...
The next step:
I'd like to find a way to change the sampler's 3 and 4 files lists but the way I found for the time being is not so practicle because I have to first make a "list comma text" file list in the combo box with the files directions. Maybe there would be a way to use an other sampler only to update files lists, or something like that?
If someone has a tip, that will be much appreciated indeed!
Unread post by nay-seven » 14 Jan 2013, 17:11
maybe you can update your add-on with a zip file with the 2 versions inside..?
and this way, someone can help you more easily about the sampler list
yommusine
Unread post by yommusine » 16 Mar 2013, 09:31
Nice work !
Marlow77
Unread post by Marlow77 » 14 Dec 2014, 09:55
How do I try this/download this? I can't seem to find it...
Marlow77
Unread post by Marlow77 » 14 Dec 2014, 10:59
nevermind... I found it! Definitely maybe drumming! Great!
Unread post by cmodica » 13 Jan 2015, 09:31
I am sorry but i can't find it to test ...
Users browsing this forum: No registered users and 1 guest
