Video to Pitch patch
niggles
Unread post by niggles » 25 Apr 2014, 08:23
I made a basic Video Pitch patch and uploaded it here.
I hadn't seen any other examples of this so hopefully it helps someone who's wanting to try it out. All you need is a webcam and then place a Midi instrument in the same rack -> use "get midi bus" as your MIDI source in. Works best with instruments which are Monophonic or Arpeggiated.
Y axis controls pitch and X axis controls Velocity.
Cheers,
Niggles
Digital Director & Programmer by Day | Musician By Night
iMac Core I7 | Usine | Logic | Leap Motion (loving it)
http://www.tribe404.com
Unread post by nay-seven » 25 Apr 2014, 10:26
Thanks to share your add on Niggles
btw, you don't need bus in this case , if you add a Midi out module in your patch, this will be linked automatically to the second patch in your rack
niggles
Unread post by niggles » 25 Apr 2014, 10:57
That's good to know as it didn't link up like a normal piano-roll and this was my solution :) I will revise my copy to use this without the Bus.
Users browsing this forum: No registered users and 41 guests
