I 'm trying to use this patch but there no module inside...
I would like to use it for increment/decrement tempo value . in my opinion it will be easier to use this in global tempo synchronisation with button "+" and "-" near X2 and /2 . the mouse is not really instinctive for me and and obliges to use it in live situation , midi with CC are not precise enough ( I always have a "jump" )
of course with this patch it will be possible to do this , but it could be too a nice improvement
What do you think?
Keys2Fader no module inside
you are right, the tempo indicator is not precise enough.
Don't forget that since the v2.64 you can create multiple key learn like
'A-B',
A to increase, B to decrease...
So you don't really need such patch?
'A-B',
damstraversaz
I forget this...thanks !
Well, I couldn't resist to create a new Keys2Fader patch after deleting the old one from the add-ons. (The old file was 130 kb? Strange...)
This new example goes a little beyond the complex key learn, adding the possibility for decreasing/increasing with two different intervals. In the patch, the Z and X keys changes the fader value with -1/+1, while holding the shift key down changes the value with -10/+10. Other keys and/or intervals can easily be used.
