error in synthesis pack with lates version of usine?
ErotiCore SteNch
Unread post by ErotiCore SteNch » 15 Aug 2011, 19:23
i just downloadet and installed the synthesis add-on
but get some error messages something like cant find vst--name--
im running the latest version of usine pro 5,7
Unread post by nay-seven » 15 Aug 2011, 19:49
have you read the install.txt and put all the folder in your personal library..?
Unread post by nay-seven » 16 Aug 2011, 12:29
as the install.txt say you need to put all the folder in your personal library, not the Usine one( and it will be easier to manage Usine update later)
ErotiCore SteNch
Unread post by ErotiCore SteNch » 16 Aug 2011, 15:09
ok
i tried creating a my personal library folder,but that wont show up in the browser
so how do i set a personal library?:/
Unread post by nay-seven » 16 Aug 2011, 15:17
you create a folder, then in your global setup/interface you give the path of this folder as patch library
you can also read this Tip
