beatformer: granular drum sampler/sequencer
soundmind
Unread post by soundmind » 21 Nov 2010, 12:04
"Inspired by transformer, beatformer is an in depth granular drum sampler/sequencer. Although it was deisigned with drums in mind, any one shot samples can be used to create original rhythmic pieces from scratch."
http://www.sensomusic.com/wiki/doku.php ... beatformer
Check preset manager or conductor for a couple quick and dirty examples.
UPDATE3:
1. Lower CPU load
2. panning fader and mono switch for each sample
3. pre gain and post vol for each sample
4. sample start and end pos can now be adjusted from the waveform display as well as from the faders.
5. new envelope activation switch and option to trigger envelope with global sequencer or with repeat triggers.
6. brand new master section with master compressor and master vol/pan controlls
7. enhanced GUI design.
Unread post by 23fx23 » 22 Nov 2010, 09:05
mmmm cool. gonna check it tonight.
soundmind
Unread post by soundmind » 22 Nov 2010, 11:14
Major Update: completely refined and streamlined interface. see top post.
Unread post by nay-seven » 22 Nov 2010, 12:10
great one too!
maybe a pan for each sample could be interesting..?
soundmind
Unread post by soundmind » 22 Nov 2010, 12:19
yes of course. how could i forget that! good suggestion. thanks. I'm also trying to figure out how to tame the CPU usage a bit.
caco
Unread post by caco » 22 Nov 2010, 22:28
Wow this is great fun Soundmind :)
soundmind
Unread post by soundmind » 23 Nov 2010, 03:21
thanks for checking it out. I am working on a more efficient version. If anyone has any suggestions of how to reduce the cpu load then please let me know...
soundmind
Unread post by soundmind » 23 Nov 2010, 10:48
Major update and overhaul. See top post
Unread post by nay-seven » 23 Nov 2010, 11:03
great !
about cpu, i know it's a headache, but you can maybe try a no bus version, only wires...?
you could win some %
soundmind
Unread post by soundmind » 23 Nov 2010, 13:33
yeah i suppose that might help. Thanks.
Unread post by 23fx23 » 23 Nov 2010, 21:26
didn't found time to check yet as still tripping with transformer and the reverse thing, but definitely will check tonight.
maybe to save cpu some subpatchs could be activated/swich off on need?
Unread post by senso » 30 Nov 2010, 14:50
just tested deeply: you're a killer man!
soundmind
Unread post by soundmind » 01 Dec 2010, 05:18
Thanks for feedback
senso wrote:just tested deeply: you're a killer man!
It's too easy in usine.
waolelaid
Unread post by waolelaid » 02 Dec 2010, 00:07
hello soundmind you say "It's too easy in usine." for some of you yes ! :lol:
really good patches !
thanx
Friedrich Nietzsche
