patch +dll ( to install in your vst folder ), usefull to use a joystick as controller .
add 3 axis , Z-rotation, 2 direction pad , 2 sliders, and 16 buttons support
must be compatible with most of gamepad and big joystick ..
Joystick Selector - Selects which joystick to assign ( up to 8 )
Deadzone % - Size of non-responsive zone at dead center of X-Y axes,as a % of total range (0 to 50%).
Smoothness - Higher values give smoother response, at the cost of a small amount of latency. Range: 1 - 5.
button 1 and 2 have a switch option ( easy to copy to other buttons..)
enjoy
(updated )
my christmas gift ( joystick patch+dll tool up to 16 buttons)
cool...i'm gonna buy some joystick to try this...thanks ...
hi nay seven
I try your joystick patch with a dance pad
i got a lot of latency
what are you mean with the patch "more sensitive " ?
thank in advance
gercha
thank in advance
gercha
L'orchestronique - foSolo
http://www.arbre-canapas.com/l-orchestr ... ideos.html
sorry gercha1 , it's an old patch and don't even remember what was this "more sensitive " patch..i feel stupid..and i've delete this sentence..
about latency , i can't do more , depending of windows , the joystick, your computer and so....
sorry again
sorry again
ok , no problem,
i try to find myself a solution,
and thanks for usinome lite,
i try it just now !!!
nice tool !!
gercha1
nice tool !!
gercha1
Users browsing this forum: No registered users and 119 guests
