a song wip
How do you use usine?
Unread post by 23fx23 » 21 Dec 2010, 16:41
i only play liveset usually but i decided to force myself to flatten some stuff in linear way, aka "songs."
here is a wip i bounce yesterday, it's some kind of psytrance.
http://soundcloud.com/fx23/nwo_wip01
Still lot of work in mixing and composition (i mixed with headphones and i think there are pb, also squashing limiter)
but any comments/reviex/sugg welcome :)
Nb: this is done with ableton:rolleyes:, but usine has been higly involved as i made a CC looper to search my automations,
and few of the psy sounds where generated in usine VSTi to mess my vsts.
Unread post by nay-seven » 21 Dec 2010, 17:23
Really trippy !
just an idea : i think i will prefer a straight end, like at at 4:34 ...?
Unread post by 23fx23 » 21 Dec 2010, 17:39
thx for comments nay :)
yeah it was going to 9mn and i quick cut to make a end of first part of 5mn, normally i have a second part more speed in 4/4
(here it's 3/4 all along), but it need still lot of work.
or indeed i will cut at 4:34 otherwise if i finish only this part as an entity and make a new different track to go after that..
waolelaid
Unread post by waolelaid » 21 Dec 2010, 18:49
hello is it a remix of "twisted " from hallucinogen ?
there are moments which looks like
fine ;)
Friedrich Nietzsche
Unread post by 23fx23 » 21 Dec 2010, 19:00
hey waolelaid i would never have imagined you listened to hallucinogen! ;)
it was one of my first trance cd but at that time i didn't really liked trance, i was more in dnb/hardtekno but now i rediscover
the way they evolved in psytrance and i dlike to find an in between the two scenes, cause i love and hate thingz in the
two genres, but that's quite harder to combine booth than i imagined..
héliouk 6
Unread post by héliouk 6 » 21 Dec 2010, 19:48
i hear it in 12/8,and was waiting for a 4/4 passage.is that you call 3/4 and 4/4?
it's cool....
Unread post by 23fx23 » 21 Dec 2010, 21:03
yes sorry 12/8 i said that wrongly because i put by bass notes on a ternary grid, i have now clues about that lol my brother try to explain me but i never understand, .yeah im working on the 4/4 partB, it will be simpler for me
Floego
Unread post by Floego » 24 Dec 2010, 18:05
optimistic, compelling and pleasant rhythm, really nice :)
Unread post by 23fx23 » 24 Dec 2010, 18:36
thanks floego.
well i had worked too much on it with headphones, when i re-heard on monitors i found mix quite bad and composition also
being a bit repetitive and always speed, so i restarted a cleaner mix on a 8mn version with better composition that take more time to install and some pause before final load, more varying with subtle breaks, i start atlast to be happy. still lot of work, but final release should be much better than this one i hope...
Floego
Unread post by Floego » 24 Dec 2010, 19:04
I will be around waiting for the newer version. :)
I always have had similar problems with the mix:
it sounds nice with headphones, and unbalanced with loudspeakers.:(
Unread post by 23fx23 » 25 Dec 2010, 02:30
yeah thats a real pain.
i have monitors but i don't run them as im in a litle flat with aweful phasy room..but ive seen it's tricky with headphones.
for exemple, on soundsystems i really like to drop only some kick and bass and just subtle ambiance, find that works better
than having too much sounds, but when hearing on headphones the same seems 'empty' and not working.... dilemna.
i made some compare today and there are really paterns that work good with one but not the other and vice versa.
also on headphones man have tendency to push too much the bass, then it's muddy on loudspeaker.. :(
mainly infra bass and reverb are impossible to feel correctly on headphones or litle speakers, so it's really hard to
find a compromise of somehing to work on big subs PA as well as cheap ipod earphones buds...
and the music im after rely a lot infra bass ;)
gurulogic
Unread post by gurulogic » 25 Dec 2010, 03:36
Sounds good on my crappy laptop speakers so it's probably gonna sound great on my HS80m monitors!
Users browsing this forum: No registered users and 42 guests
