No answer from support
I have problem to register or I can't contact Sensomusic.
Juanjo
Unread post by Juanjo » 04 Jul 2013, 12:20
Hi there,
Sorry to post here but I've emailed support twice (on 27/6 and again yesterday) with no response...
Anyway, I purchased a Pro upgrade last october, which I believe included Hollycock once it was done if I recall correctly... I'm back to making music after being away for a while so I just tried to download Hollycock but I can't (it says I should be a platinum member which apparently I'm not). Could you please clarify this for me? I think I should have access to Hollycock but I'm not really sure as it's been a while... thanks so much in advance.
Cheers,
JJ.
Unread post by nay-seven » 04 Jul 2013, 12:49
Sorry for this inconvenience Juanjo
i suppose you use contact@sensomusic.com ..?
seems there's a problem with this address
solved now anyway, welcome back
Juanjo
Unread post by Juanjo » 04 Jul 2013, 23:29
Yep, I was using that address, that explains it :) Solved indeed, thanks so much.
Cheers,
JJ.
gd2
Unread post by gd2 » 20 Aug 2014, 08:40
[unrelated -- doing the first-reply-then-add-new-topic-despam-thing] --
I got no auto-reply w/ pw email when registering, but got a swift response with contact@...
So now I can add a topic. :-)
_g
