Posted: 17 Jul 2008, 20:16
[3.68d] 08/07/17
some small bugs fixed.
You can skip this release.
fixed bugs
- in the demo folder the mdspFlanger plugin is invalid
- Error in the sequencer midi module
- the Wii nunchunk doesn't work properly
other
- lighter demo zip package
- the jazzmutant lemur demo is now available as an add-on
[3.68c] 08/07/15
Another of last minute update.
You can skip this update if everything rocks on your system.
The 3.68.. will be the official release for a long time, and I'll try to make it bug free as much as possible.
In parallel, I'm working on a major improvement of Usine and I'll try to develop both versions (the actual and the new one) at the same time. You'll have info about the new one very soon.
fixed bugs
- Sometime the selection is tricky in listbox modules (very old bug finally fixed!).
- Various display bugs in listboxes.
- Error when deleting a Local Interface Builder.
- Some curious behaviour when creating a Local Interface Builder...
- Usine can't work with a sample rate at 88200 Hz.
- Sometime the 'snap to grid' in the Interface Builder can reduce small containers.
[3.68b] 08/07/11
A couple of last minute updates. Concerns especially the VST version which was built with an older version of Usine...
For the rest, you can skip this update if everything rock on your system.
improvements
- re-sizable preset panels
- snap to grid for containers
fixed bugs
- CC curves 4,5,6,7,8 don't work in the pianoroll
- the filter panel is not updated in the interface builder
- the vst version package. The 3.68a was built with an older version of Usine VST...
[3.68a] 08/07/10
Major improvement
new modules
- data and audio Mixers
- Nintendo Wii remote manager
- draw points curve
improvements
- draw a CC curve directly in the pianoRoll
- load up to 16 Midifiles in the pianoRoll
- new zoom button in Step, XY, Oscilloscope panels
- new preset panel design
- easier object selection in the Interface builder
- the minimum delay value in the delay module is now 0 ms
- new 'start on activation' option in the sampler module to enable/disable the
re-starting from the beginning on the activation of the patch (only in loop mode)
fixed bugs
- solo button in the InterfaceControl/MixerOutput module can crash Usine
- when double-click on a slider the edit field appears on the up-left corner of the interface builder.
- after rename a slider the inlet isn't updated in the patch
- midi notes in the 'fader midi notes' module are displayed an octave too high.
- Better compatibility with VST plugs (CSR, T-Racks etc.)
- the size of the containers in the interface builder changes when lock/unlock
- strange behavior of containers when the grid size of the interface builder = 1
- the width of the remote panel is too large on 1024x768 screens
fixed bugs
other
[3.68c] 08/07/15
fixed bugs
[3.68b] 08/07/11
improvements
fixed bugs
[3.68a] 08/07/10
Major improvement
new modules
- draw points curve
improvements
fixed bugs
