New Versions of Usine [3.63] and VST [3.63 beta9]
Announcements
Unread post by senso » 10 Apr 2008, 20:28
[3.63] 10/04/07
you can skip this release if Usine works fine on your system.
Now Usine is separate in two packages (two zip files) Usine VST and Usine Stand Alone
improvements
- new faster event schedule in the Sequenced Steps, Lines and Switches.
in response to the topic http://www.sensomusic.com/forums/viewtopic.php?id=783
- new Freezz patch in the library
- the Vst parameters affectation forms, displays used parameters
- Controls display a small icon when they are affected to a Vst Parameter
fixed bugs
- reading of Vst automation curves in Ableton Live
- audio freezes in Ableton Live (Vst version)
- various display/refresh bugs of control panels in the Vst version
- better memory release/allocation
Unread post by nay-seven » 11 Apr 2008, 12:46
Thanks for this new one again !!
