New Versions of Usine [3.62] and VST [3.62 beta8]
Announcements
Unread post by senso » 08 Apr 2008, 13:14
Version [3.62] and [VST 3.62 beta8]
You don't need to update if the 3.61 works properly.
Now the VST package contains a VST-fx and a VST-i version of Usine
fixed bugs
- Solve the problem 'nsp.dll' not found at the startup.
- the 'load' button on monome/molarVst now works
Usine as a VSTi in Nuendo
mahtazz
Unread post by mahtazz » 08 Apr 2008, 15:39
Unable to load Usine VST 3.62 beta 8 in Acid Pro 6.0d
Unread post by senso » 08 Apr 2008, 18:43
please by mail, easier for me.
Unread post by senso » 08 Apr 2008, 19:33
works at home with Acid Pro 6.0d, but only with an asio driver as input!
