Page 1 of 1
Usine Hollyhock 4.0.200128 and 4.0.200129 update
Posted: 29 Jan 2020, 14:36
by nay-seven
4.0.200129
- [usine] registration procedure fails
4.0.200128
- [usine] bad reconnection after sub-patches modifications
- [usine] bad initialization of the physics engine
- [usine] quicklinks don't work when connected to an audio-out module
- [usine] errors on move-sections in the grid
- [usine] various stability issues solved
- [usine] graphical issue on path's wires
- [usine] binds can be lost when a workspace is loading with audio engine ON
- [usine] new Ctrl/Cmd+F2 to print the video screen
- [usine] video engine optimizations
- [usine] possible flickering in on the video out windows
- [usine] auto hide mouse cursor in output video window
- [module] various improvements in the data-generator-random
- [module] smpte-set can now be in the grid
- [module] possible crash in video-to-3d-points module
- [module] audio-sampler random/next mode doesn't work for loop-mode = 2,4,6,etc. bars
- [module] possible bad connection in the usine-patch-settings
- [module] pianoroll events input doesn't keep the MIDI channel
