usine hollyhock 3.0.180 update
Announcements
Unread post by nay-seven » 25 Oct 2018, 17:54
[large]3.0.180[/large]
improvements
- GUI design for long patch's captions.
- Settings_panel is now displayed in single column.
- Better drop items mode in the grid_panel.
bugs
- Midi learn on the presets_panel combobox are not saved.
- Once-in-poly doesn't work for color-input.
- Video-geometric-resize can crash memory.
- Data-mix-mixer module doesn't work properly when mix-values=0.
- Potential hard crash of Usine when BLOC size > 128.
x.iso
Unread post by x.iso » 25 Oct 2018, 19:05
cool, hopefully my problem fixed once and for all, so I can complete my synth and upload as add-on!
Unread post by sm_jamieson » 24 Mar 2019, 17:43
I have noticed a problem in SDK User module captions starting with this version.
I note the fix:
I don't know exactly what this fix is, but I am finding the size of text drawn with sdkFillText()
is inconsistent and sort of "wobbling" sometimes when the mouse is pressed.
Has anyone else seen anything like this ?
Simon.
Unread post by nay-seven » 24 Mar 2019, 18:25
if you think it's a bug you can reproduce, use this address for report please:
support@sensomusic.org
Unread post by oli_lab » 24 Mar 2019, 23:30
don't have this behaviour with my "videotext" user module.
Unread post by sm_jamieson » 26 Mar 2019, 01:57
Well I have recreated most of my problem workspace from scratch and the problem is not showing up.
I still have the old workspace that shows the problem but it is too complex to use as a test case, and if I simplify it too much the problem goes away. I did notice that when the problem occurs, the Paint() routine is called an extra time, but the Rect and font size passed to sdkFillText() were the same.
It seemed rather a coincidence there was a fix in the first problem Usine release 3.0.180, "GUI design for long patch's captions". Perhaps there is a minor backward compatibility problem.
Anyway since my new workspace is OK I will not investigate this any further.
Simon.
Unread post by senso » 26 Mar 2019, 08:08
ok,
try to use the support@sensomusic.com next time, it's the best way to communicate with the team if you have troubles.
