Posted: 22 Oct 2017, 21:57
[large]3.0.144[/large]
improvements
- Improved ArtNet test in the setup
- Implementation of node and sub-net settings in ArtNet engine
- MIDI-split (multi split) module
- Drop-file-mode option in the sampler
- Improved light-direct-dmx and light-direct-artnet modules
- Vertical-lock mode on sequenced-steps and array-display modules
- Clear-drop-file-name inlet in modules
fixed bugs
- Possible issues if 2 webcam are connected with the same name
- Control positions can be lost when a wkp is saved in IB view
- Sometime, racks are reloaded with wrong outputs settings
- Array-expand doesn't work as expected
- Sequenced-points modules is not created properly
3.0.143
3.0.142
3.0.141
intermediate versions
improvements
fixed bugs
3.0.143
3.0.142
3.0.141
