New add-On: MultoBlon
Announcements
Unread post by nay-seven » 28 Jan 2014, 15:17
MultoBlon
MultoBlon is a multi effects and is made of a simple filter and a delay.
The idea is simple: each ball, moved by the physics engine, change 2 parameters of each effect.
The originality of this patch is that you can activate /stop each ball individually with a fade effect.
More infos on its wiki page
Important: Remember you can now directly download add-ons from your browser/add-ons tab, by using the update from internet button.
dave dove
Unread post by dave dove » 15 May 2014, 12:50
i realise this may be a dim question
but
how is this patch cycling through samples?
dave
Unread post by nay-seven » 15 May 2014, 13:15
the patch itself is only an effect, no samples inside.
I provide a rack to illustrate the effect, so the samples are in the minimized sampler and are in random mode
is this answer your question.?
Users browsing this forum: No registered users and 194 guests
