Page 1 of 1
Posted: 31 May 2013, 12:06
by nay-seven
[large]Usine Hollyhock Update 3 (version 1.00.236)[/large]
Can be downloaded in the
download area.
- Most of reported issues fixed.
see
the release notes for more information
To upgrade just copy the content of your old
/Config folder within the MacOSX packet or the WIN directory.
Posted: 31 May 2013, 13:53
by naarud
thanks for the update, hope you start to breathe a bit more
i still have a question about the update process.
there are some absolute paths in the Default-settings.ini file (FNAM fields in [DEFAULT DEVICESE#-]) that are not updated after using the new version for the first time. it doesn't seem to really affect the whole behavior of the soft and i didn't managed a clear process to get a change on these values (i got a change, where absolute path disappears, replaced by the pat name alone but can't understand how i landed here...).
should i care about this? if not, i still want to understand
, when are those default settings used? may it lead to potential errors for some workspaces after an update?
Posted: 31 May 2013, 21:26
by waolelaid
Hi Nay it's a record ! 2 updates in about fifteen,
and i think it's not finished for the days coming
Best
Posted: 31 May 2013, 22:17
by yommusine
Kudos for the great support.
Try to sleep once in a while guys
Cheers !
Posted: 31 May 2013, 22:31
by Thomas Helzle
Thank you!!!
