Usine 5.20b
Announcements
Unread post by senso » 29 Jul 2010, 19:43
[5.20b]
This version fixes a small bug in the RGB Color module. You can skip this release if you don't have any color/layout issue.
[large]fixed bugs[/large]
- Color inversion in the RGB Color user module
[5.20]
Important update which add many important new features and fixes several bug.
[large]improvements[/large]
- new demo examples
- new tab in the browser to get a direct access to add-ons.
- new caption in master insert patches
- more templates, especially in an empty area
- new 'params' inlet/outlet in the VST module to get/set all the VST at once, with array's.
- 'open selector' in the color selector module to open the color window
- new 'target' parameter in the preset module
- new 'target' parameter in the send mouse message
- new help system: if the favourite language page doesn't exist, the English one is displayed by default.
- new find files strategy in LoadPatch and LoadWorkspace modules
- midi learn is now enabled for all controls whatever their location
- extended VST parameter’s concept to retrieve the param’s real displayed value
- ON/OFF values in the Toggle module
- refresh problem in the array module
- refresh problem in the piano roll after a preset recall
- Hard VST bug when on initialization the BLOC size is not equal to 128
- Draw Panel module is always repainted
- repeated scans in the browser can freez Usine
- INPUT_QUERY in scripts can freeze Usine
