Usine V5.05
Announcements
Unread post by senso » 19 Feb 2010, 20:00
[5.05]
Important update. Solves several bugs and few improvements.
Update it especially if:
- you use Vista64, XP64
- you use a touch-screen under Vista or XP
fixed bugs
- XY panel is not correctly initialized (with 2 balls)
- The "on" button of the control panel is not properly repaint.
- Vista 64 and XP 64 incompatibility problems
- various issues with buses when buses names are affected dynamically
improvements
- new modules "Audio Buses" send and receive
- Grouped Switches implementation
- new "tolerance" option in the setup/interface. If you feel that Control Panel buttons are too small...
- option in the setup to set the dblClick behavior in IB mode (not necessary in Windows 7)
- cpu improvements of the Buses engine when names are affected dynamically.
