Usine 4.21 important update
Announcements
Unread post by senso » 22 May 2009, 22:21
[Usine 4.21]
Important synchronization bug fixed.
improvements
- better scrolling management in the global interface builder
fixed bugs
- the text size in listbox buttons collection is not stored in the patch
- the store outlet of the preset manager sends always a 1 value
- synchronization drift between VST's and Usine internal synchro
- the Midi Time Code SMPTE synchro doesn't work properly for frame rate greater than 24fps
Unread post by 23fx23 » 22 May 2009, 23:01
thanks a lot
Unread post by nay-seven » 22 May 2009, 23:14
great !
thanks !
ethnix73
Unread post by ethnix73 » 22 May 2009, 23:16
Thanks Olivier!
Seb.Dub
