Important news about the 4.01
Announcements
Unread post by senso » 02 Nov 2008, 15:32
[4.01]
Usine 4.01 Touch Screen Edition is out!
Usine FREE is no longer limited except that you can't edit sub-patch or scripts.
Also, the add-ons are now accessible to all users FREE & PRO.
It means that with the the FREE you can create simple patches or use ready made ones from the Library or from the add-ons section.
The price of the PRO version is now 70€, for one year of free updates. After one year updates will cost 40€ (stays unchanged).
improvements
- layout available for separators& Panels modules
- symmetric option in the step sequencer to display bars in a symmetric way along the middle axis.
- background Bitmap option in the text/comment module
fixed bugs
- in the sequencer midifile, sometime the first note is not played
- in some zoom conditions the grid in the sequencer can be strange...
- various layout bugs.
[4.0 beta 13]
improvements
- midi & key learn allowed in patches of the sequencer!
fixed bugs
- the aux send on/off now appears in the global remote
- a blank remote panel when the patch selection changes in the grid
- an array input can't have a zero length in scripts
- the Rack mode listbox popup menu is greyed
- compatibility problems of presets saved with older versions
[4.0 beta 12]
improvements
- new aux send on/off switch in the track out mixer
- the sequenced step, lines, point, switches duration goes now up to 10,000 seconds
- all string inlets in Usine can now be manipulated in real time
- new preset x16 module
fixed bugs
- various small display bugs in the Interface builder
- the Destroy export procedure missing in User Modules examples
- right click midilearn popup is now more contextual...
- aux send order problems in the track out mixer
- bad wavedisplay/pitch+gain & wavedisplay/pitch+gain+speed subpatches initialisation
- moving muti-selected patches in the sequencer is tricky.
- small bugs in the preset storage in sub-patches
[4.0 beta 11]
fixed bugs
- double click problems on the navigation bar (touch-screen mode)
- local host monitoring (OSC) now works (new option in OSC setup)
[4.0 beta 10][/b
fixed bugs
- wrong Data/Counter with Max sub patch in the module library
- bad object selection in the interface builder
- various details
[4.0 beta 9]
fixed bugs
- bad multi copy of patches in the sequencer timeline.
- better velocity adjustment in the pianoroll
- better snap to grid of markers in the sequencer
- snap to grid now available on the right part of patches in the timeline
- can't adjust the separator & panel module size and position in the interface builder.
- bad record button update in the Dashboard.
- bad width inlet update in the ramp module
- better zooming in the sequencer
- various display bugs in the piano roll
- Various package problems in the VST version
improvements
- reverse play mode in the pianoroll
- quicker response of buttons (see http://www.sensomusic.com/forums/viewtopic.php?id=1059)
[4.0 beta 8]
fixed bugs
- bad audio input affectation in the setup (when inputs are duplicated)
- bad wire addition when both have a null input.
- display details in the wire monitor panel
- the list box inlets in User Modules aren't properly saved
- endless callback loop in User Modules (when a modal window is displayed)
[4.0 beta 7]
improvements
- fill ramp array module
- clear inlet queue data
fixed bugs
- some various display bugs in control panel & Module Panel.
[4.0] Touch Screen Edition
see the demo videos here
more than 100 improvement:
- touch screen management
- 16 audio in/out
- clear/save/open current track command in the main menu
- new possible location for Interfaces builder windows: patch or parent patch
- new rack mode : 'grid', 'rack' or 'play all'
- customizable layouts for all displayed controls (set the colors you want to all controls).
- reset + reset values in steps modules (step, step-midi, lines, switches, points, array)
- no more auxiliary busses order limitations
- expand module command in patches (see manual)
- some PianoRoll improvements
- clear current CC curve in PianoRoll
- more quantize options in the sampler/ grainSampler :2,4,6,8,10,12,14,16 bars
- New command in the main menu to hide all the popup windows (tab] key)
- new mapper curve module design (shows now a cursor to display the current position)
- new Audio Selector sub-patch in the module library
- new Wave Display sub-patch in the module library
- better record (direct to disk) engine
- better multi-thread optimization
- more precise Send Midi Time Clock module in the Library
- new conductor module more powerful; see compatibility notes.
- the color of the line in the remote panel is the same than the control color
- at the startup of Usine, the last main window position is memorized
- debug mode in the setup for user modules developers
- more precise schedule in the mouse down outlet of the separator/panel module
- the audio out is cleared when a patch activation is turned off
- 'visible' inlet/outlet in the Interface Builder module
- the mapper curve can process audio flow (see 'audio quality' parameter)
- a sub patch can be locked to prevent modifications
- the master section shows only actives in/out
- new ‘default value’ parameter in faders, knobs
- preview workspaces/patches info's in the the browser window
- the conductor now saves all the patches of the grid in rack mode (not only the selected patch); see compatibility notes.
- the 'show remote' button is visible in grid mode (not only in patch design mode)
- French Quick Start
compatibility notes
- the new interface control/conductor panel module is not compatible with older version.
- because of the new save procedure in the conductor, you can have some small compatibility problems with older versions.
Unread post by bsork » 02 Nov 2008, 22:32
Cool, Olivier!
Actually, something like the symmetric option had crossed my mind, but I forgot to add a suggestion. Psychic powers, eh?
ethnix73
Unread post by ethnix73 » 03 Nov 2008, 01:01
Never thought of symmetric option, but great idea Olivier!
Thanks.
Seb.Dub
Stephan326
Unread post by Stephan326 » 29 Dec 2008, 07:08
I cannot access the addon section. Above it states that Free and Pro would have access to add ons.
Unread post by bsork » 29 Dec 2008, 07:50
Stephan326 wrote:I cannot access the addon section. Above it states that Free and Pro would have access to add ons.
That has changed (and may change back again): see http://www.sensomusic.com/forums/viewtopic.php?id=1237
