Usine 4.0 out soon!
Announcements
Unread post by senso » 03 Sep 2008, 11:51
[4.0] Touch Screen Edition
see the demo video video here
more than 100 improvement:
- touch screen management
- 16 audio in/out
- clear/save/open current track command in the main menu
- new possible location for Interfaces builder windows: patch or parent patch
- new rack mode : 'grid', 'rack' or 'play all'
- customizable layouts for all displayed controls (set the colors you want to all controls).
- reset + reset values in steps modules (step, step-midi, lines, switches, points, array)
- no more auxiliary busses order limitations
- expand module command in patches (see manual)
- some PianoRoll improvements
- clear current CC curve in PianoRoll
- more quantize options in the sampler/ grainSampler :2,4,6,8,10,12,14,16 bars
- New command in the main menu to hide all the popup windows (tab] key)
- new mapper curve module design (shows now a cursor to display the current position)
- new Audio Selector sub-patch in the module library
- new Wave Display sub-patch in the module library
- better record (direct to disk) engine
- better multi-thread optimization
- more precise Send Midi Time Clock module in the Library
- new conductor module more powerful; see compatibility notes.
- the color of the line in the remote panel is the same than the control color
- at the startup of Usine, the last main window position is memorized
- debug mode in the setup for user modules developers
- more precise schedule in the mouse down outlet of the separator/panel module
- the audio out is cleared when a patch activation is turned off
- 'visible' inlet/outlet in the Interface Builder module
- the mapper curve can process audio flow (see 'audio quality' parameter)
- a sub patch can be locked to prevent modifications
- the master section shows only actives in/out
- new ‘default value’ parameter in faders, knobs
- preview workspaces/patches info's in the the browser window
- the conductor now saves all the patches of the grid in rack mode (not only the selected patch); see compatibility notes.
- the 'show remote' button is visible in grid mode (not only in patch design mode)
- French Quick Start
fixed bugs
- fader Midi Note, Fader Vertical, Curve of Points are not stored in the conductor
- bad CoeffToDb module initialization
- most of reported bugs fixed
compatibility notes
- the new interface control/conductor panel module is not compatible with older version.
- because of the new save procedure in the conductor, you can have some small compatibility problems with older versions.
Unread post by bsork » 03 Sep 2008, 12:16
I'm flabbergasted! Couldn't image so much new and exiting and useful stuff coming now!
!!!!!!!!!!!!!!!! :) !!!!!!!!!!!!!!!! :D !!!!!!!!!!!!!!!! :) !!!!!!!!!!!!!!!! :D !!!!!!!!!!!!!!!! :cool:
La Tenaille
Unread post by La Tenaille » 03 Sep 2008, 12:39
Hello Olivier, it seems great!
A pity I don't have a free hand left on stage to try your touch screen improvement ;)
Unread post by grego mondo » 03 Sep 2008, 12:52
when is soon ?
so excited
Unread post by senso » 03 Sep 2008, 12:54
This mode allows very quick manipulations: I use it on stage, just trigg with the right hand (I play double-bass)
amiga909
Unread post by amiga909 » 03 Sep 2008, 14:30
whoooooa!!!!!!!!!!!!!!!!!! outerwordly!!
you are a magician, Olivier!
your usine4 spell is enchanting, now chance to resist i am already lost in reverie!
wanted to quote the features I like the best but my post would be too long :)
touch screen support really is fascinating, so obvious every audio soft would need that.
wonder what the French quick start is?
...is there a risk we loose our girlfriends to usine? ;)
héliouk 6
Unread post by héliouk 6 » 03 Sep 2008, 18:15
monstrueux!!!!!
martignasse
Unread post by martignasse » 03 Sep 2008, 23:34
well, so....
really great job you have done here
can't say more....for now
stanlea
Unread post by stanlea » 04 Sep 2008, 06:54
What model of touch screen will receive the gold members ?
You know my name (look up the number)
Unread post by senso » 04 Sep 2008, 09:01
this one!
Stefan
Unread post by Stefan » 04 Sep 2008, 09:24
Great work! Where the heck can I get a touch screen... :)
runagate
Unread post by runagate » 04 Sep 2008, 23:06
The new site design certainly looks snazzy.
You remember me ranting about Usine and touchscreens, no? Mine broke many months ago :_(
nofish
Unread post by nofish » 25 Sep 2008, 19:33
Hi Senso,
to be honest, I'm a bit "concerned" about the touch screen edition.
At the moment I'm running my old PIII laptop with my Usine live setup and the CPU use is almost fully maximised, so I'm a bit afraid that I won't be able to run the new version with all the new features anymore (I'd probably don't need them anyway since I haven't a touchscreen).
So my questions are: Is the touch screen version optional and will it consume more CPU than the current version?
Unread post by senso » 25 Sep 2008, 22:16
the next version will have about the same CPU consumption. Just a better multicore optimization, but a PIII your not concerned.
Ticasso
Unread post by Ticasso » 27 Sep 2008, 11:59
Edit : Sorry ! I was thinking that it was a french project.
so, i've just discoverd the Senso via the french musician forum 'Audiofanzine'
since i 'was dreaming for a tactil interface ... it comes ! simlpy "monstrueux"
is there a date to see the Touch Screen Version ???
this project is genious ...
Unread post by nay-seven » 27 Sep 2008, 12:37
hello ticasso and welcome
can you please edit your message , this forum is only english ...sorry
Vincent
Unread post by Vincent » 28 Sep 2008, 20:30
Ticasso wrote:Sorry ! I was thinking that it was a french project.
You're right, it's a french project. But since it's for (almost) any musican on this earth, so, well, french is not quite the right langage for this!
And yes, you're right, it's genious. But don't say that to Senso, he won't believe you!
Welcome here and enjoy.
nofish wrote:I'm a bit afraid that I won't be able to run the new version with all the new features anymore (I'd probably don't need them anyway since I haven't a touchscreen).
First: I'm almost certain you'll be able to run it. Second: you just need it, even if you don't use touchscreen (just like me)! Third: keep the version you use now, just in case (I mean, just in case it becomes collector, of course).
vincent michel
composer & novelist
mn
Unread post by mn » 30 Sep 2008, 02:57
Looking forward to v4. Keep up the good work, Olivier :)
runagate
Unread post by runagate » 30 Sep 2008, 05:06
I might have a wicked deal on 2 (sadly serial port to USB) touchscreens so I can involve non-PC afficianado people with intuitive user interfaces to control virtual instruments and fx! $125
Man, so busy I don't even know if the guy is still selling them, hard to decide if the latency is worth it but I want the touchscreen edition so bad (I've been ranting about it for over a year!) I can taste it!
amiga909
Unread post by amiga909 » 03 Oct 2008, 23:51
when does it come?
nag nag.
i cant resist to nag! i come EVERY day to this site ;)
Unread post by senso » 04 Oct 2008, 10:03
normally next week for the first official beta
Users browsing this forum: No registered users and 142 guests
