new version [3.68a]
Announcements
Unread post by senso » 10 Jul 2008, 22:48
[3.68a] 08/07/10
Major improvement
new modules
- data and audio Mixers
- Nintendo Wii remote manager
- draw points curve
improvements
- draw a CC curve directly in the pianoRoll
- load up to 16 Midifiles in the pianoRoll
- new zoom button in Step, XY, Oscilloscope panels
- new preset panel design
- easier object selection in the Interface builder
- the minimum delay value in the delay module is now 0 ms
- new 'start on activation' option in the sampler module to enable/disable the
re-starting from the beginning on the activation of the patch (only in loop mode)
fixed bugs
- solo button in the InterfaceControl/MixerOutput module can crash Usine
- when double-click on a slider the edit field appears on the up-left corner of the interface builder.
- after rename a slider the inlet isn't updated in the patch
- midi notes in the 'fader midi notes' module are displayed an octave too high.
- Better compatibility with VST plugs (CSR, T-Racks etc.)
- the size of the containers in the interface builder changes when lock/unlock
- strange behavior of containers when the grid size of the interface builder = 1
- the width of the remote panel is too large on 1024x768 screens
moody33
Unread post by moody33 » 11 Jul 2008, 12:06
Miam-miam!
Yummy-yummy!
Scrunch-scrunch.
Crac-crac.
nofish
Unread post by nofish » 11 Jul 2008, 17:47
Senso, thanks for the huge amount of work you put in and giving us such a cool software!!!
(Simply amazing seeing the remote panel size bug I reported being fixed one day later...)
Stefan
Unread post by Stefan » 11 Jul 2008, 17:52
Thanks again for fixing the IK Plugs! Great job!
Users browsing this forum: No registered users and 44 guests
