new version [3.64] beta13
Announcements
Unread post by senso » 19 May 2008, 13:57
Stand alone [3.64a]
Vst [3.64a beta13]
Improvements
- new sampler tools in the library
- multi-banks conductor storage,
- patches on the time line (sequencer mode) keep their position when the master tempo changes
- the zoom and scrolling in the sequencer is more ergonomic.
- adjust the precision of values in the step data, midi, line modules
- new vertical grid in the step data, midi, line modules
- quantize options on listboxes
- quantize options on Faders
- the piano roll cursor position moves after a paste (allows fast duplication)
- in the piano roll, the File Number change is now immediate (no note are lost)
- new Option in the setup: a midi/key learn can be applied to all the patches of the a rack.
- in the interface builder, now you don't need to select the parent patch of a control to make a midi/key learn.
- midi learn available on on all the bypass switches of the track in racks mode
Fixed Bugs
- the LFO module sends chaotic values when min=max
- various display bugs in the piano roll
- the loop length of the piano roll isn't correctly updated when the file number changes
- various display bugs with pluggo runtime
- listbox button value is now stored in the conductor
- various memory release and crashes problems (VST)
- in some situations synchro 'restart' button doesn't work properly
- midi note fader module now sends integer values
- GUI problem in ReValver (VST)
- bank changes in EZDrummer
nofish
Unread post by nofish » 19 May 2008, 15:31
Wow.
Thanks for the update, Senso.
The multi-banks conductor storage was a suggestion of me.
Amazing seeing it fullfilled so quickly. :)
I have announced the update at KVR if you don't mind.
http://www.kvraudio.com/forum/viewtopic ... 17#3074217
Unread post by senso » 19 May 2008, 15:49
thanks for the announcement!
runagate
Unread post by runagate » 19 May 2008, 20:21
wow!
I'm, once again, quite impressed!
Sorry I've not been around; I'm hardly on the net nowadays :-(
But I'm working on a treat for Usine.
Unread post by bsork » 19 May 2008, 21:26
Lots of nice additions - thanks!
stanlea
Unread post by stanlea » 19 May 2008, 22:26
Thanks.
You know my name (look up the number)
Vincent
Unread post by Vincent » 20 May 2008, 12:07
Thanks Olivier for your hard work!
It's one more step toward perfection!
vincent michel
composer & novelist
