5.2.220106 Major improvement
Apple-Silicon CPU compatible
-[usine] new engine more stable and faster
-[usine] full compatibility and optimization for MacOS Apple-Silicon
-[usine] new command in the inspector-panel to search strings and media file names
-[usine] new help hints on the modules in the patching window
-[module] all selectors and dispatchers, new option to set select in the range [0..N-1]
bugs
-[module] the audio-analysis-envelop-follower gain doesn't work
-[module] convolution and reverb generator, potential audio glitches
-[usine] grid command assignations are not saved properly
-[usine] direct-to-disk can record glitches when an object is not enabled
-[usine] most of reported bugs solved
Usine Hollyhock 5.2.220106 update
Users browsing this forum: No registered users and 190 guests
