Usine Hollyhock 5.1.211124 update
Announcements
Unread post by senso » 24 Nov 2021, 09:47
Important update 5.1
-[usine] overall optimization of the process engine and messages queue speed
-[usine] many new details changes and small improvements
-[module] network-tcp-client, better reconnect strategy
-[module] interface-design-listbox faster add items operation
-[module] audio-analysis-envelop-follower new RMS output
-[module] usine-trace-data, midi & text new option to add the line in the LogFile.Log file
-[module] control-switch new small-led-opacity option
-[module] panel-ruler various new layout options
-[usine] new option to isolate a control from global color change of parent: ignored-in-parent-global-color
bugs
-[usine] on the plot panel, channels list is not sorted by alphabetic order
-[module] also-visible-in-IB option doesn't work properly
-[module] better accuracy of network-osc-receive especially for triggers
-[module] video-modules possible mismatch when one of the inputs is invalid
-[module] fixtures-modules possible conflict when the received event is NULL
