New version (1.018)
Announcements
Unread post by senso » 30 May 2006, 17:11
- 20-30% faster audio engine
- New Midi player module with record capabilities (JdH suggestion).
- Headphone monitoring of the input sound in the track mixer (lalo suggestion)
- Easy and fast MidiLearn with right click
- Midi "panic" button added to the dashboard (bsork request)
- Few add-ons available for download.
- Most of submitted bugs fixed.
Thanks for your help.
laserbeak43
Unread post by laserbeak43 » 30 May 2006, 17:16
Thanks Oliver!
lalo
Unread post by lalo » 30 May 2006, 17:18
woahh!!
i gonna try it on the tomorrow's gig :)
..if it will crash...well...time for a drums/bass solo ..lol
thanx senso!!!
laserbeak43
Unread post by laserbeak43 » 30 May 2006, 18:30
i cant wait till i get the use of this. and i can use it like i want. i will do a dnb solo as well almost made one in synthedit but there is a lot of bugs
Unread post by senso » 30 May 2006, 18:33
be careful,
the remote file has changed and is not compatible... Sorry but I was obliged...
I'have tested it for 3 concerts.
Normally stable.
Unread post by bsork » 31 May 2006, 12:31
Looking forward to installing and testing the new version after the kids have gone to sleep!
Bj?rn S
laserbeak43
Unread post by laserbeak43 » 31 May 2006, 18:25
to wake them up? :P
Unread post by bsork » 01 Jun 2006, 09:22
...hopefully not! Headphones only at home, I'm afraid.
I installed v1018 and it worked fine and I liked the new features, although I think I noticed some quirks. Since I'm in the process of integrating Usine with Reason, both controlled from my Ozonic, I haven't really been trying to check out new features or checking whether the "quirks" are bugs or just me doing something wrong (again).
I'm not quite sure if I could detect any improvement of the CPU usage though. One thing that really is strange (and this is not new in v1018), is that the CPU rises alarmingly when the audio engine is running and the Global Remote window is opened. Right now I'm not sure (at work...), but I think it sometimes also happens when assigning MIDI to patches.
For those interested(?), I like to tell something about how I'm trying to use Usine: I'm mainly a guitar player but have been dabbling with synths etc since before MIDI. The setup I'm working on is mainly inteded to be used by me when improvising together with a drummer friend of mine.
I like to set things up to have as many possible ways of controlling and playing stuff with as little hassle as possible - and still not loose track of what is going on in the PC - and then change it on the fly. The possible number of control destinations in both Usine and Reason are of course vast, and I can't possibly keep track of too many, so I've been doing quite a bit of thinking to end up with a combination of what parameters is controlled from what Ozonic program. At the same time this has a been a learning process, and some of the patches have been redone once or twice since I realised I had been doing things more complicated than what was neccessary.
Yesterday evening I think I got most of this "framework" it set up correctly, and tonight I'll add and tweak patches making my shiny new "super-mixer/mangler/synth/sampler" ready for jamming tomorrow! It'll be fun, I'm sure!
So long, and get more sleep than I've been getting the last few days!
Bj?rn S
laserbeak43
Unread post by laserbeak43 » 01 Jun 2006, 15:39
a fot controller with midi? and maybe one of those midi controller pickups for guitars? and a midi translator program? or some translation methods in usine?
can usine handle sysex?
Unread post by bsork » 02 Jun 2006, 09:38
It seems to that Usine could handle any form or MIDI message as long as you're willing to code.
I do have a foot controller with MIDI signals sent to a patch bay, the pre-amp and TC Fireworx, but I think I'll stick to my present setup and keep that MIDI setup separate, just routing audio into Usine. I don't have any MIDI guitar, and it's been ages since I tried one. Actually, it made me sound like I could play keyboards...
What I try to achive, is having as many possibilities at hand with as little effort (aka button pushing) as possible to do the sampling/MIDI/mix thing on the fly, so as not to interrupt my guitar playing too much. Unless I'm actually playing the keyboard of course...
The method I've used, is setting up a number of programs in the Ozonic controller/interface with quite a lot of common CCs in all or some of them. For instance, the output level and Aux1/2 sends for the first four Usine tracks are on the some faders and rotaries in all of the programs, so I can change that no matter if the other controllers are assigned to controlling Reason.
Except for the normal keyboard type of data - NoteOn/Off, PW, Mod etc - I've created patches in Usine with MIDI triggers that either sends something internal in Usine, or translates it to some MIDI data sent to Reason. By the way, I've used Maple MIDI to connect the two programs, with Usine as the master. I suppose I could have mixed MIDI from Usine with the "Remote" option in Reason - which automatically reassigns CC to the current device - but I prefer to leave that be and keep the overview of what's happening from Usine.
Bj?rn S
lalo
Unread post by lalo » 02 Jun 2006, 12:27
senso wrote:be careful,
Normally stable.
everything went fine ;)
1.018 mission 1 succesful ;)
Unread post by senso » 03 Jun 2006, 11:24
Actually, Usine can't handle sysex midi Messages. The intern engine is ready for that, but I have no experience... I never use external expanders.
I need your experience!
Tel me what it could be interesting to do with sysex in Usine. It should be easy to implement.
Please, feel free to post suggestions about that point.
unguitar
Unread post by unguitar » 03 Jun 2006, 17:01
after having loaded 1.018, I don't see the outputs B and C on my mixer track anymore.
Going back to 1.016 shows them again.
Where do I set them ?
thanks,
luca
______________
luca
www.unguitar.com
laserbeak43
Unread post by laserbeak43 » 03 Jun 2006, 17:29
senso wrote:Actually, Usine can't handle sysex midi Messages. The intern engine is ready for that, but I have no experience... I never use external expanders.
i use my emu-mp7 for live performances. with the software i've created the mp7 is a controller. when i use midi ox as a midi translation tool, i send a midi message to midi-ox from one of the 16 trigger buttons on the mp-7 it then translates this midi message into a sysex message that i specify and sends it back to my mp-7. when the mp-7 recieves this message, it changes the controller configuration almost instantly, to make the 16 knobs and 16 buttons controll other features of the software.
Unread post by senso » 04 Jun 2006, 01:08
Don't worry
In the new version output buses are stereo by default. In you use more than 2 outputs modules the buses are transformed into surround automatically.
Try to put 5 out modules, for example.
Unread post by senso » 04 Jun 2006, 01:13
How does your sysex looks like?
How big?
Could you send me a sample?
unguitar
Unread post by unguitar » 04 Jun 2006, 15:33
Don't worry
Please clear me about this as I can't understand it.
What if I want to send a channel to multiple outs ?
Do I have to load addouts in the strip ?
thanks,
luca
______________
luca
www.unguitar.com
laserbeak43
Unread post by laserbeak43 » 04 Jun 2006, 18:13
How big?
as you can see in this image, when the first note, 74 is pressed, it sends a ctrl message on channel 14 and i have it set to chain to the next message wich is a ctrl message after a delay of one millisecond and the last message after a delay of two milliseconds. successfuly completing a sysex message.
the same for note number 75. the two values under the note 75 sysex message are a nother translation.
click the thubmnail for a better view of the image
Unread post by senso » 04 Jun 2006, 19:24
It's exactly as before. Only the display mode has changed.
Aux busses are still in 5.1
Just put 4 outputs modules on the patch to display the mixer output in 5.1
Unread post by senso » 04 Jun 2006, 19:27
thanks for explanation
I have to find a way to edit a set of MIDI messages to send to the output.
Let me think about it
laserbeak43
Unread post by laserbeak43 » 05 Jun 2006, 18:51
basicaly what it does is turn any midi message into any other form of midi message. and it is also chainable wich makes 3 part messages like sysex possible.
Unread post by senso » 06 Jun 2006, 08:37
on your example, if I resume:
TEST : if you receive NoteOn 74:
--> Send CtrlChg 0 80
--> wait 1 ms
--> Send CtrlChg 32 0
--> wait 1 ms
--> send ProgChg 4
Actually, this can be done easilly by Usine, using the Create midi message and the Wait modules.
For small SYSEX, we can use Array module to record, store, send.
The problem, under Usine is for thoose larger than 2KByte.
Unread post by bsork » 06 Jun 2006, 08:50
A little note to laserbeak:
The MIDI output module seems (to me, anyway) to default to channel 1. That is, unlike in the other modules, when you need a constant value of some sort, the MIDI channel should not just be entered directly into the field, but instead come as input data, for instance in the form of the Const module. Is this a bug, Olivier?
Bj?rn S
laserbeak43
Unread post by laserbeak43 » 06 Jun 2006, 19:12
interesting info guys thanks!
Unread post by senso » 06 Jun 2006, 21:42
Are shure of that?
the channel of the midi output module can be set to any value directly in the field (double click) or with a const value or whatever.
It'works on my system(s)
laserbeak43
Unread post by laserbeak43 » 07 Jun 2006, 20:28
senso wrote:on your example, if I resume:
--> wait 1 ms
--> wait 1 ms
--> send ProgChg 4
the wait modules? dont they wait one cycle? will that be a ms? can i specify a wait time?
i'm actualy asking the same question in another post here http://sensomusic.com/forums/viewtopic.php?id=100
i havent been able to test it cause i have my midi gear set up on my laptop wich cannot run usine the asio isnt stable enough.
-edit-
cant set up the midi gear on this computer yet cause there is no space at the moment.
Unread post by senso » 07 Jun 2006, 21:00
The "wait one cycle" wait for a single cycle, generally 64 samples (1.5 ms at 44100 KHz)
Good suggestion, I'm gone add the possibility to set the wait time to any value.
see:
