Usine [3.57] 08/02/28
intermediate version (you can skip this update if everything works fine...)
improvements
- background record in the sampler module (will be documented later); Recording and playing process can be totally separated (playing any file while recording at the same time)
- the minimum screen resolution protection has been disabled; Usine can now run on the Asus eee pc...and it rocks!
fixed bugs
- affectation problems in the Variable and Multiple Variable modules; solve the problem on the Send/Receive NRPN patches
- pause in the grain sampler now works...
- problem with the conductor recall when controls are "not stored in conductor" solved
New Version of Usine [3.57]
- senso
- nay-seven
great ! thanks senso...
- cmodica
Fantastic !!! Thank you Olivier.
multiphone
Hello Olivier,
Thanks a lot.
You program faster than a make music...
Best
Hervé.
Thanks a lot.
Best
Hervé.
damstraversaz
I suppose we need to install xp on the asus eee pc ( correct me if I'm wrong but the pc works under a linux system) ?
- senso
yes you need XP
