Usine Hollyhock 3.0.139 update
Announcements
Unread post by nay-seven » 26 Sep 2017, 10:11
[large]3.0.139[/large]
improvements
- flow-Is-NULL module
- array-limit-size module
- improvement of the MIDI trace on wires
- more accurate [shift+mouse move] on integer faders
- presets can now be renamed by [alt+click] on the preset panel
- user Modules are unloaded after destruction
- length mode option in MIDI-transformer module
- possible font name for values and captions
- improved error trace messages for patches
- use hardware acceleration option reintroduced
- zero pad option in array-extract
- disable-hidden-strings option in the setup/expert
fixed bugs
- MIDI in device patches not plugged correctly
- invalid number of colors in matrix modules
x.iso
Unread post by x.iso » 26 Sep 2017, 11:10
x.iso
Unread post by x.iso » 26 Sep 2017, 12:30
Big thanks to Senso for bringing improvements and especially for hardware acceleration! It seems to draw UI better and I get at least 10% less CPU load on same workspace.
Unread post by sm_jamieson » 28 Sep 2017, 12:17
Yes, thank you Senso for including these ideas so quickly !
Unread post by 23fx23 » 29 Sep 2017, 21:51
Damn the unload user dll works as a charm, so much gain time :)
Also had sluggish ui sometimes, now with HW accell pof fast AF back
i was remaining on hh2 cause of this, now time to move on HH3 :)
rockssss!
Unread post by oli_lab » 01 Oct 2017, 22:11
23fx23 wrote:Damn the unload user dll works as a charm, so much gain time :)
yesss !
sephult
Unread post by sephult » 04 Oct 2017, 11:11
Awesome about the unload!
drakh
Unread post by drakh » 06 Oct 2017, 12:20
:D uiii
Users browsing this forum: No registered users and 81 guests
