New Version 3.53
- senso
Optional release.
- compatibility with echo indigo sound card
- new Swing it! for midi and data flow sub patch and script. Add a Swing parameter to your grooves.
- new Color Schemes (thanks to Nay Seven)
- senso
I'm sorry!
- senso
The Data version is a sub-patch and you'll see, very easy to build.
But the midi one is much more complex, especially to handle NOTE OFF messages...
JamminFool
- New member
nice release! thanks.
i noticed that the version number still says 3.52 though.
JamminFool
- New member
also noticed that many of the buttons in the Looper Slicer are sized such that the label text does not fit correctly. never noticed that before so i'm not sure if that is new...
