This release is important if you use the sequencer mode with large files.
Skip it if you don't have any problem and you don't use the record (direct to disk) function.
improvement
- New record (direct to disk) options, to record directly in the sequencer.
- The default workspace (loaded at the start up) keeps its real name and can be saved normally.
fixed bug
- new option in the setup to set the disk buffer size (reading buffer of audio files).
- Wave display 'show loop' doesn't work, and inlet invisible.
- Problems (cpu & freeze) in the sequencer with large wave files.
- Mouse wheel (zoom) in the sequencer
- Better memory allocation and release.
Update 3.52
Thanks you sir, that was an important for meThe default workspace (loaded at the start up) keeps its real name and can be saved normally.
Cool,cool
K
damstraversaz
very interesting
thanks
thanks
Users browsing this forum: Bing [Bot] and 3 guests
