Usine Hollyhock II 2.0.078 update
Announcements
Unread post by senso » 01 Aug 2015, 08:45
[large]2.0.078[/large]
Few improvements and bugs solved.
The good news is that Usine has now a real band limited Oscillator which sounds good.
Also an important bug has been discovered on automations curves of the wave panel.
improvements
- new band limited oscillator module
- added random LFO mode
- up to 8 joysticks can be opened at the same time
- clip value options in the change scale module
bugs
- impossible to create curves points on a wave panel
sephult
Unread post by sephult » 02 Aug 2015, 16:36
That is awesome news, putting to use right away!
The original oscillator sounded amazing to begin with, very excited to hear and implement in my synth patches.
Thanks Senso!
-s
fractalist
Unread post by fractalist » 05 Aug 2015, 13:28
super update !
clip option in change scale will be veeeeery very useful !
loneboat
Unread post by loneboat » 25 Aug 2015, 18:06
Thanks for the update!
What is a band-limited osc? I'm googling, but not finding a simple answer.
sephult
Unread post by sephult » 25 Aug 2015, 19:47
It's the oscillators for a sound source.
They now include Triangle and separated Pink and White Noise...as well as being band-limited to prevent aliasing.
They sound much warmer and more smooth than the original.
Before they had a really raw harsh sound (which I didnt mind, actually I still like them too).
The LSeeD synth I put in the add-ons now uses the bandlimited oscillators, love them.
-s
