Usine Hollyhock II 2.0.071 RC11 update
Announcements
Unread post by senso » 02 Jun 2015, 17:29
[large]Usine Hollyhock II 2.0.071 RC11 update[/large]
Important download, the 071 has several important improvement and fixes reported bugs.
For a better stability, you should upgrade it.
improvements
Changes "loop on bar" and "loop on beat" behavior, more accurate
New bypass inlet on most of audio modules added
New Patch Bypass module to bypass the current patch
New default color set more punchy
New modules design in patches
New option in the setup/expert to disable the audio missing files dialog box
New option in the setup/expert to enable rounded setting on controls
New modules to get the language ID of Usine and used by the system
Simplification of the color palette file
bugs
Sync midi to grid displayed inverted
Wrong fade in/out durations on grid elements
Zoom scale reinitialization in old versions grid
Chat notification sound invalid
Ticket #099 : The color palette doesn't work properly on some controls
Ticket #022 : Problem with Enttec DMX-USB PRO mkII device
Drag&Drop from listbox doesn't work properly
Unread post by oli_lab » 02 Jun 2015, 22:37
sephult
Unread post by sephult » 02 Jun 2015, 22:51
Thanks senso, keeping me super busy here too :)
loneboat
Unread post by loneboat » 03 Jun 2015, 02:58
senso wrote:[large]Usine Hollyhock II 2.0.071 RC11 update[/large]
improvements
bugs
[img align=L]http://www.sensomusic.com/img/features/ss12.png[/url]
Silly question: How do I upgrade? :-o
sephult
Unread post by sephult » 03 Jun 2015, 04:06
There is a Wiki Loneboat!
Installation and Update
If you need more help let me know.
-s
Unread post by senso » 03 Jun 2015, 19:10
[large]Usine Hollyhock II 2.0.071b RC11 update[/large]
Important download, Buses names are not loaded correctly
Sal
Unread post by Sal » 03 Jun 2015, 22:41
Hey,, I was just about to update things, good timing, thanks,,
(Rushes to work..)
Unread post by oli_lab » 03 Jun 2015, 23:30
YESSS ! the busses are OK, thanx Senso !
sephult
Unread post by sephult » 04 Jun 2015, 05:59
Usine Hollyhock II 2.0.085 Senso Location Advisory so we know when he is going to update so quick :lol:
I can't keep up with you man, how do you do it!
Great catch.
BTW what happened to the email alerts?
-s
loneboat
Unread post by loneboat » 05 Jun 2015, 20:30
How do I upgrade? Just download and unzip to a new directory? How do I preserve my settings?
La Tenaille
Unread post by La Tenaille » 05 Jun 2015, 20:48
sephult wrote:There is a Wiki Loneboat!
-s
Unread post by cmodica » 05 Jun 2015, 20:49
Instruction for update are here :
how Update and install
loneboat
Unread post by loneboat » 05 Jun 2015, 21:06
Thanks cmodica! I still get confused navigating the wiki, since Google often returns results pointing to old versions. Thanks again!
Unread post by cmodica » 06 Jun 2015, 15:06
you're welcome.
Users browsing this forum: No registered users and 216 guests
