Usine Hollyhock Update #4 (1.01.007d) is available for download
Announcements
Unread post by senso » 28 Jun 2013, 09:04
[large]Usine Hollyhock Update 4 (version 1.01.007)[/large]
Major release.
Can be downloaded in the download area.
The free version is also available.
improvements
- new Rack layout as columns
- option in the setup to have Patches, Grid, etc in a floating windows for multi monitors
- Pianoroll, Scripts, Browser windows resizeable
- racks panels can be minimized.
- scrollbar in Interface Builder
- user curves in Sample player module
- audio engine optimization
- various improvement in the Physics engine
- the Preset Panel contains 32 presets.
- plugins now compatible at patch/wkp level (win32, win64, osx32 and VST, AU)
- optimization of midi events flow
- many other improvements
- most of reported issues fixed.
see the release notes for more information
how to upgrade
To upgrade just copy the content of your old /Config folder within the MacOSX packet or the WIN directory.
Then, rescan your plug-ins.
[large]Usine Hollyhock Update 4 (version 1.01.007a)[/large]
Minor release.
Upgrade only on French version, other languages can skip this release.
fixed bugs
- some inlets/outlets are missing in the French version
[large]Usine Hollyhock Update 4 (version 1.01.007c)[/large]
Correction release.
fixed bugs
- important crashes can occur on apply polyphony for big sub-patches
[large]Usine Hollyhock Update 4 (version 1.01.007d)[/large]
Correction release. Concerns the pianoroll module only.
fixed bugs
- in the pianoroll, some midi notes can be played in a wrong order
drakh
Unread post by drakh » 28 Jun 2013, 10:50
when will be the 1.01.007d version for windows avialable ? (in downloads for windows there is 1.01.007c as latest release)
Unread post by nay-seven » 28 Jun 2013, 11:42
yes, you're right, corrected
Thomas Helzle
Unread post by Thomas Helzle » 28 Jun 2013, 11:57
Wow - with the speed of updates you roll out I really look forward to that auto-update you talked about ;-)
Cheers,
Tom
drakh
Unread post by drakh » 28 Jun 2013, 12:39
thank you
sephult
Unread post by sephult » 29 Jun 2013, 12:50
I agree with Thomas! Very awesome to have updates rolling out so often! I can hardly keep up.
-S
Users browsing this forum: Bing [Bot] and 12 guests
