Usine Hollyhock march news
Announcements
Unread post by senso » 08 Mar 2013, 22:13
Hello to the community,
We are all impatient to discover the new version of Usine.
We are so busy that we forgot to give news. We apologize.
I know, we are late... But we prefer delayed the launching date and give you a good first beta version. It's a choice and I'm sure that you understand.
Actually we are focusing on
- the patch library
- the quick start manual
- the user manual (more than 3000 pages)
We can't announce a precise date but be sure that it will arrive very soon.
You can take a look on the following screen shot.
Senso & the Sensomusic team.
Floego
Unread post by Floego » 08 Mar 2013, 22:46
Great work Senso!
For upgraders, given the changes from the old version there's no doubt the manual will be an important piece for Hollyhock :cool:
daviche
Unread post by daviche » 09 Mar 2013, 12:30
Impatient indeed, but I'm sure we all agree with your choice.
Good work and good luck !
Composer - guitar player
Dell INSPIRON 16 5645
Windows 11
RME Fireface UC - EVO 8
caco
Unread post by caco » 09 Mar 2013, 14:15
Looks well worth the wait to me :)
waolelaid
Unread post by waolelaid » 09 Mar 2013, 15:47
Hi Olivier it seems to be really delicious looking
and thanks for the big manual i hope it 'll be
illustrative more than the actual manual
will it be downloadable ?
i have real troubles to read on a computer
Thanx in advance
and take the time you need
Regards
Friedrich Nietzsche
Unread post by 23fx23 » 09 Mar 2013, 19:56
looks good!
Thomas Helzle
Unread post by Thomas Helzle » 09 Mar 2013, 21:51
Very nice!
My impatience is driven by the fact that the old Usine no longer works on my Windows 8 x64 machine. It gets confused all the time and interprets midi off as on and more such nonsense, so it's pretty much unusable.
But I fully agree with your choices anyway ;-)
Cheers and thanks for the update!
Tom
r.erorr
Unread post by r.erorr » 09 Mar 2013, 23:06
Thomas Helzle wrote:Very nice!
Tom
Hey, does OSC work on win8 machine?
Thomas Helzle
Unread post by Thomas Helzle » 10 Mar 2013, 15:25
I never used OSC so I wouldn't know, but why shouldn't it?
AndrewChi
Unread post by AndrewChi » 10 Mar 2013, 15:42
Thomas Helzle wrote:My impatience is driven by the fact that the old Usine no longer works on my Windows 8 x64 machine. It gets confused all the time and interprets midi off as on and more such nonsense, so it's pretty much unusable.
The old/current Usine always had a buggy MIDI-implementation, it drove me near nuts in the past, but I found a workaround!
Get a solid MIDI-capable DAW (like Reaper or Cubase), install LoopMidi (freeware) and route all your hardware midi from the DAW to seperate virtual MIDI-ports from loopMIDI. Then, get Usine to recieve only the loopMIDI-channels and it should work 10 times more solid. It works for me on Win7 64bit, I only get MIDI-gibberish every now and then in Usine this way.
If you make your setup completely MIDI-remotely controlled (no on screen actions) you can even record your full set in your DAW as MIDI tracks, and play it back in different tempo's, pitch,... This way you have true event-based recordings of your sets and the possibilities for re-recording and additional production are endless! But that's just a plus!
Hope this can help you.
I also respect Senso's choices about the release-date, but I must say I'm also impatient, since I have a big release-concert end of this week and the biggest risk on stage is still my Usine standalone version...
Godspeed Senso!
Unread post by senso » 10 Mar 2013, 16:01
for info,
Midi issues of the V5 belong to the past, the Midi engine has been totally rewritten.
Thomas Helzle
Unread post by Thomas Helzle » 10 Mar 2013, 20:13
Senso: That is very good news!
andrewchi: Interesting! I was never sure what exactly is causing the problems. I use a very old LMK3 Keyboard from Doepfer which tends to send "Midi Noise" from sheer age on some controllers every now and then, which surely doesn't help the issue, but no other DAW I use ever got confused as Usine by this.
And I never found a keyboard I like better (It's the very first pre-hammer-action version).
But I think the real trouble with Usine started with Windows 8, which otherwise doesn't give me any audio related problems.
Do you find LoopMidi better than CopperLan? I recently switched from the first to the latter but haven't put it through it's paces yet.
Thanks for the ideas and inspiration!
And best of luck with the concert :-)
Cheers,
Tom
seamus
Unread post by seamus » 11 Mar 2013, 04:40
I also can say the loop midi helped usine alot for me under windows 7!
secretkillerofnames
Unread post by secretkillerofnames » 11 Mar 2013, 08:59
I've had no issues running Usine on Win7 with a Samson Carbon controller. My only problem is I'd rather be in OSX with all my other plugins! ;)
The other day I got the disk access / DSP freeze issue I haven't had since switching from XP to OSX 5 years ago.
Alain Vankenhove
Unread post by Alain Vankenhove » 11 Mar 2013, 21:55
thanx Mr Senso & team for your news ... :P
Asus A7C dual core/RME Fireface UC/Axiom 25/MPD 24/Trumpet/BCR2000/FCB1010
ahonoe
Unread post by ahonoe » 16 Mar 2013, 15:20
Thanks for update Olivier. I know it's tough work but keep at it. You are very near the finish line.
Regards,
Scott
Thomas Helzle
Unread post by Thomas Helzle » 28 Mar 2013, 17:32
Any easter eggs cooking? ;-)
Cheers,
Tom
Unread post by woodslanding » 05 Apr 2013, 00:16
I'm hoping there is no april news because the beta is just SOOOO close...... ;)
Zat0
Unread post by Zat0 » 05 Apr 2013, 15:49
Hello! I was wondering if a free version of Hollyhock is gonna be available ??
Looking forward to try it !
Thanks for your work.
headphoner
Unread post by headphoner » 07 Apr 2013, 19:31
Any Usine Hollyhock april news?:)
Users browsing this forum: No registered users and 188 guests
