Usine 5.70.035 Update
Announcements
Unread post by senso » 29 Nov 2011, 14:15
[large]Usine 5.70.035 Update[/large]
Important bug fixed on the HID Device module (which appears in the 5.70.034); should be updated if you use it.
fixed bugs
- the HID device module doesn't work properly
see
Release Notes
artificial
Unread post by artificial » 29 Nov 2011, 18:27
Thanks for all this fast updates! :)
gercha1
Unread post by gercha1 » 29 Nov 2011, 21:43
merci pour la rapidité,
gérald
Unread post by 23fx23 » 12 Dec 2011, 04:30
can't wait to test new osc stuff. thx!
