[large]Usine 5.50.70.034 update[/large]
improvements
- added a new couple of lines in the control panel layout to adjust the size of the ON/OFF button
- new global pre listen level fader in the Setup/Audio Out/
- new trace data option in the HID Device
- various layout details improved
fixed bugs
- various bugs in the Conductor module, when loading at the startup.
see
Release Notes
Usine 5.70.034 Update
hello olivier
i have some problems with the hid module
since the new release 570 034
some internal error when i change the hid number,
is it just me or ?
thanks in advance
gérald
is it just me or ?
thanks in advance
gérald
L'orchestronique - foSolo
http://www.arbre-canapas.com/l-orchestr ... ideos.html
Issue confirmed.
Will be solved in the 5.70.035, posted very soon.
