Usine 5.70.031 Update
Announcements
Unread post by senso » 11 Oct 2011, 17:34
[large]Usine 5.70.031 Update[/large]
Important bug fixed. Should be updated if you use the conductor.
fixed bugs
- sometime, conductor value's aren’t properly recalled when the fade time is greater than 0
see
Release Notes
AstralV66
Unread post by AstralV66 » 11 Oct 2011, 19:48
I can't seem to get an authorised download window appear.
All that happens is the window saying my download is being activated appears, it says this for a few minutes then the window goes blank.
Is there a problem ?
Regards
Dunc
Unread post by nay-seven » 11 Oct 2011, 20:01
no, it's normal
check your mailbox, you'll receive a personal link
AstralV66
Unread post by AstralV66 » 11 Oct 2011, 20:17
No links from the previous tries.
However I have just tried to get activations again and got the download links this time...strange.
Anyway, thanks nay-seven.
Users browsing this forum: No registered users and 271 guests
