Usine 5.70.026 Update
[large]Usine 5.70.026 Update[/large]
Few improvements and bugs fixed in this release.
improvements
- new Event thru module
- new bitmap inlet in the Container module
- new SET_CTRL_POS_PC Internal Messages Language (IML) command
- new SET_CTRL_SIZE_PC Internal Messages Language (IML) command
- new smooth option in Quadratic distance 2D module.
- new Kalman filter script for data filtering.
fixed bugs
- Random Data bad initialization when synchro = play button
- Send Usine Internal Messages doesn’t work properly in poly sub-patches
- OSC (Open Sound Control) Setup deactivated in the Usine Stage version
improvements
fixed bugs
Excellent! Glad to hear about the IML poly fix....
One question:
What does the PC stand for?
One question:
@Joffo78 :
event thru
@woodslanding
this add a percentage position ( left and top defined in percent ([0..1]) of the parent panel size. ) , check IML
event thru
@woodslanding
Event thru : what a good news !
A really good way to organize connection points.
Please make also Array and String thru
Core I7, Focusrite Pro 24, Emu Keyboard.
this module works also with Array's and strings!Len wrote:Event thru : what a good news !
Ok great !
Can you confirm thant it does not take any cpu power at all ?
Thanks.
Thanks.
I read the wiki page on event through....
Can someone give a list (or at least an example) of what is "not nomally stored in preset manager"? I thought the PMs stored everything.....
