Usine 5.70.025 Update
Announcements
Unread post by senso » 18 Aug 2011, 20:09
[large]Version 5.70.025[/large]
fixed bugs
- various issues on Conductor recall of User’s modules.
- CPU overload in Formant filter
[large]Version 5.70.024[/large]
improvements
- the Additional Audio Input module is now more efficient.
- new anti-aliased option in Curve of Points and Lines (sequenced) layout
- new point size option in Curve of Points layout
fixed bugs
- the Additional Audio Input module doesn’t work properly.
- few corrections in the Cross Fade Module.
- the Mapper Curve is not properly saved
- small display bug in ListBoxes when the list is empty
[large]Version 5.70.023[/large]
Few corrections in the CrossFade Module.
[large]Version 5.70.022[/large]
This version solves various problems in the CrossFade and the DelayAudio Modules.
[large]Version 5.70.02[/large]
Usine Free, Usine Stage, Easine & Usine Pro 5.70 are available for download.
Hundreds of improvements and new features.
see
What's new ?
Product comparison
CleverConQueso
Unread post by CleverConQueso » 19 Aug 2011, 06:20
Thanks, Senso. If we have, say, a formant filter in an old patch and it's updated, do we delete the object from our patch and drag in the new one or is that not necessary?
-CCQ-
Unread post by nay-seven » 19 Aug 2011, 08:52
No, not necessary, cause when Usine will built the patch , it will look for the module and will find the new one ( except for user modules you can have in several versions in your personal library )
héliouk 6
Unread post by héliouk 6 » 02 Sep 2011, 14:25
i've just try the new version after a 3 monthes break;and i want to say it's enormous,thanks to the community for this work, usine is the best !! thank you all!
Users browsing this forum: No registered users and 103 guests
