Free New Packs (Matrix, Midi, Surround)
Announcements
Unread post by senso » 06 Mar 2010, 12:05
Three new great (and free) packs are available in the download section:
Matrix Pack by Martin Fleurent
Contains a new matrix user module totally integrated in Usine.
» more info
MIDI Utilities Pack by bSork
The ultimate Midi manipulation pack.
» more info
Surround Pack by Hervé Birolini
All you need to create surround projects.
» more info
Thanks to all the contributors: Martin Fleurent, bSork, Hervé Birolini.
Unread post by 23fx23 » 06 Mar 2010, 22:31
hot stufff!!
Unread post by nay-seven » 06 Mar 2010, 23:38
yes !
huge work guys !!
many new white nights !
multiphone
Unread post by multiphone » 08 Mar 2010, 08:50
Yes, i'm happy for the commubity and all the other user of Usine.
Best
HB
Lines / Points / Squares
http://www.hervebirolini.com/
Clearscreen
Unread post by Clearscreen » 09 Mar 2010, 00:46
senso wrote:Surround Pack by Hervé Birolini
» more info
http://www.sensomusic.com/wiki/lib/exe/ ... dss01s.jpg
Have to give a special thanks to this pack - looks like I'll be producing a 20 speaker installation for someone later in the year and this will be perfect for it!
gurulogic
Unread post by gurulogic » 09 Mar 2010, 01:33
Yes, I am excited for using this for some experimental surround setups for outdoor DJ and live performance shows this summer.
First I need longer cables for my speakers and some way to raise them all off the ground (just a little sound system. Only 8x 1000 watt subwoofers and 6x 1600 watt tops ;) )
And I have to replace the amps that were stolen...:(
multiphone
Unread post by multiphone » 09 Mar 2010, 11:14
Yes i'm sure that few little patchs are a door for spacial démocratization and experimentation in Usine.
I'm really happy if you enjoy it.
This is just a BEGINNINGS !
Best.
HB
Volumetric
Unread post by Volumetric » 03 Jul 2011, 11:39
Sorry for the stupid question, but i cant seem to see these packs any where in the download section.
Unread post by nay-seven » 03 Jul 2011, 12:22
yep, sorry we're working on many changes those days
they have moved to the addon section...
you can download them directly from Usine browser now;)
Volumetric
Unread post by Volumetric » 03 Jul 2011, 14:02
Thank you for the quick response nay-seven, brand new to usine, feeling very much like a fish out of water :)
waolelaid
Unread post by waolelaid » 03 Jul 2011, 22:14
Hi very good sunday thanx for all
Cheers :D
Friedrich Nietzsche
caco
Unread post by caco » 03 Jul 2011, 22:49
Awesome work, thanks to all involved and thanks for sharing :)
Unread post by nay-seven » 13 Aug 2011, 14:58
For the Surround Pack , i know that Hervé Birolini is working on a new version, for the matrix one, gone to check it, but i think the last version of the module is in Usine matrix folder.but all the examples and utils patch are ok .
ErotiCore SteNch
Unread post by ErotiCore SteNch » 13 Aug 2011, 15:31
ok thanks just wanted to be certain i had the newest versions:)
Users browsing this forum: No registered users and 152 guests
