update Usine 5.50.52 poly
Announcements
Unread post by senso » 14 Mar 2011, 17:39
[large]Usine / Easine 5.50.52[/large]
This version contains several improvements and fixes some important bug.
Also contains a new library called DJ set which provides up to 7 new DJ oriented FX.
You should download this update.
Please read the notes bellow.
Improvements
- [module] new Formant Filter module
- [module] new multichannel crossFader module
- [module] optimization of the delay module (2x faster)
- [module] new ramp module. The old version (5.25) of the ramp is reintroduced for compatibility.
- [module] sampler : new "long filename" outlet
- [library] new DJ FX pack (contains 7 special DJ FX)
- [library] new version of Bit Crusher
- [library] new version of Reverse
fixed bugs
- [module] the keyboard module doesn't work properly
- [module] bad initialization of the 1-X module
- [module] bad initialization of the delta module
- [conductor/preset] some time you're obliged to press the recall button twice
notes
- on this version some conductor/preset lines on array's and steps modules aren't
recalled properly and you're are obliged to press recall two times.
This bug will be solved if you re-save your presets/conductor lines.
ethnix73
Unread post by ethnix73 » 14 Mar 2011, 18:01
Thanks olivier,
Cool, i thought it was a problem coming from my patch :)
Seb.Dub
waolelaid
Unread post by waolelaid » 14 Mar 2011, 19:42
hello , no longer available ?
good evening :)
Friedrich Nietzsche
waolelaid
Unread post by waolelaid » 14 Mar 2011, 19:51
oops it came back sorry :)
Friedrich Nietzsche
damstraversaz
Unread post by damstraversaz » 14 Mar 2011, 20:19
it seems that the version is 5.50.51 and not 5.50.52 on the download section.
Unread post by 23fx23 » 14 Mar 2011, 21:30
yes it seems is 51 mmmm can't wait!
cool, me too i had to press PM twice sometimes, was failing debugging my script ;)
waolelaid
Unread post by waolelaid » 15 Mar 2011, 02:33
same for me didn't receive the link but
no need to worry i'll retry later :cool:
Friedrich Nietzsche
capitan mission
Unread post by capitan mission » 15 Mar 2011, 03:48
Hi, I receive it.
I suppose that the number (52 instead of 51) is a simple error. I downloaded it and is v 5.50.52
Great work!
I have a question: Witch is the way to update it? I copy/paste the new folder above the old version, only the archives with the same name are replaced. But I lost my Global setup.
Unread post by nay-seven » 15 Mar 2011, 08:57
Don't have have any problems to download this morning , maybe a temporary problem on the server yesterday night..?
can you retry and tell us..?
And i confirm, the link is named 5.50.51 but it 's the correct version 5.50.52
@Capitan mission, the better way is the inverse, just unzip the archive in a new folder, then load your global setup file and your master section if needed ( you must ,of course have save them before...global setup/file save as...and file /save master section as)
caco
Unread post by caco » 15 Mar 2011, 09:03
Got my link but took around 20 minutes to receive. Download said 5.50.51 but when you run Usine it is actually 5.50.52 :)
Unread post by senso » 15 Mar 2011, 10:17
yes the actual version is the 5.50.52. It's only a typo issue.
fixed now.
sorry
multiphone
Unread post by multiphone » 15 Mar 2011, 10:23
I can not get a download link ... after three attempts.
One yesterday and two this morning.
Strange
HB
Lines / Points / Squares
http://www.hervebirolini.com/
headphoner
Unread post by headphoner » 15 Mar 2011, 10:54
Problem with dowload link just resolved for me
thanks
multiphone
Unread post by multiphone » 15 Mar 2011, 11:36
Yes,
All is Ok Now
Best
HB
Unread post by senso » 15 Mar 2011, 12:14
probably a server overload!
waolelaid
Unread post by waolelaid » 15 Mar 2011, 17:50
hello , yet no longer available ?
well i'll retry tomorrow :lol:
good evening
Friedrich Nietzsche
Users browsing this forum: No registered users and 167 guests
