update Usine 5.50.40 poly
Announcements
Unread post by senso » 18 Feb 2011, 10:45
[large]Usine / Easine 5.50.40[/large]
This is the first 5.50 update which contains several improvements and fixes several bugs.
Recommended download.
improvements
- More efficient panic button,
- new dashboard design,
- [sampler] the gain inlet is now smoothed to avoid audio clicks (on fast modifications)
- [conductor] the selected track is no longer modified during a conductor recall
- [setup] possibility to change the midi channel of devices
fixed bugs
- [pianoroll] various display bugs.
- [pianoroll] some copy/cut bugs solved
- [sampler] an artefact can occur the first time a sound is played.
- [Easine VST] is 2xin 2xout
multiphone
Unread post by multiphone » 18 Feb 2011, 13:09
Thanks a lot this update !
HB
Lines / Points / Squares
http://www.hervebirolini.com/
headphoner
Unread post by headphoner » 18 Feb 2011, 14:02
the gain inlet smooth is really useful !
i'm working on a graind cloud recorder sampler with polyphony at this moment, can you add different window in the grain module as in the grainsampler ?
Unread post by senso » 18 Feb 2011, 19:48
actually not, only the Hanning type.
Ken29
Unread post by Ken29 » 19 Feb 2011, 20:14
And the sampler is now glitchless !
Kenan
moody33
Unread post by moody33 » 20 Feb 2011, 21:50
I've test the latest version and wowwww ! Very great evolution since my actual 4.22 version ! I'm not sure to use it for audio ( because of my unstable windows computer ), but I've just upgrade usine to the last version simply for supporting this software as I think it's the best ever made, the other reason I've upgrade it , is the fact that I believe that you need time (so money ) to build it under macintosh ! :D
So, at the moment , I'm just waiting my new account activation to dowload usine pro ! :P
Moody.
Unread post by senso » 21 Feb 2011, 10:08
thanks Moody, we are happy to see you again around here!
Actually we are studying the possibility to develop Usine for MacOs but it will be a long way...
