Usine 5.25 beta 8
Announcements
Unread post by senso » 02 Sep 2010, 21:09
[large]Usine 5.25 beta 8[/large]
All reported bugs of the beta 6 are solved. Important bugs in the IML fixed.
[large]improvements[/large]
- array's input in the Draw Objects module
- up to 128 objects in the Draw Objects module
- new layout option to draw connexions between objects in the Draw Objects module
- parameter type ptPointerBitMap, ptPointer, ptLed added in scripts
- array's parameters are saved automatically in scripts except if SetDontNeedSave is called
- new 1-X and X+1 math modules
- new window parameter in the grain sampler module
[large]fixed bugs[/large]
- all reported bugs fixed.
- audio glitches in the VST version
[large]Usine 5.25 beta 6[/large]
Probably the most important update since the v5. It contains many important improvements and fixes several important bugs.
Usine 5.25 is AIFF compatible, globally faster and takes less memory.
It is still announced as a beta version but after, few buses issues corrections, the beta6 is now very stable
You should download it.
beta 6:
- the Delay module sounds better.
- new Compile&Init and Compile&Reload menus for scripts
- few new IML instructions: PAUSE, CREATE_UID, GET_CAPTION
- VST Randomizor template added
beta 5:
- Aiff sound files compatible
- Zero crossing is active now in the sampler during the recording process, if the option is activated.
- better audio quality and synchro in the Grain Generator module
- new on/off parameter in the send bus module
- Midi-learn is now allowed on all the buttons of the navigation bar in IB mode
- better size adjustment when moving/resizing controls.
- new browser/Add-ons design
- new protect mode as hidden string
- better Audio to Midi (pitch tracker) sub-patch
- new Active Line Number module, to get the selected line in the grid
- new navigation bar design (IB mode)
- new Midi Expand voices Midi Tool script
- new Math/Bit Operators OR, AND, XOR, NOT, SHL, SHR available as scripts
- new improved Random Law Generator sub-patch
- new options in the global IB "maximize if ON (Grid & IB)" and "maximize if ON (IB only)"
- Usine graphic engine is globally twice faster.
- Scripts take less memory
- audio protection in the Filter module to prevent instability
- new target parameter in the mouse module
- new SET_LAYOUT instruction in the IML
- new FaderColor Module.
- in the Sequenced Pianoroll, we can now scroll the cursor position.
- problems with negative numbers in the RandomData module
- the 'edit layout' function is sometime tricky...
- various graphic refresh problems when the ASIO driver is down
- small refresh issue in the preset panel on recall
- sometime Midi/Key learns aren't properly stored in the patch
- often, the Midi setup is lost...
- the Midi Sequencer diplicates Midi Events in bar mode
- various conductor issues with copy/past bank
- refresh problem when a VST window is reduced as a thumbnail
[large]comments[/large]
- the scale parameter of Faders/Knobs is no longer in the layout settings but is now in the module settings (as it use to be in the V4)
- the color selector is now opened with a double click instead of single click.
multiphone
Unread post by multiphone » 02 Sep 2010, 21:40
Hello Senso,
Congratulation.
A ton of responses in fact in this version.
Simply marvelous !
HB
Lines / Points / Squares
http://www.hervebirolini.com/
Unread post by 23fx23 » 02 Sep 2010, 22:12
wow wow wow all that in a such speed amazing
there seems to be lot of new jewels!
really don't beleive it!! more than my mind was after at the moment!
arrays for draw and 128 + connections is a killer idea.
array saved is soo coool
and the rest
arf
Unread post by nay-seven » 02 Sep 2010, 22:54
whaoo, love this draw connections features !! a new world for Usine !
ethnix73
Unread post by ethnix73 » 02 Sep 2010, 23:07
As always impressive work and done so fast!
Seb.Dub
Floego
Unread post by Floego » 03 Sep 2010, 16:07
thanks!, I would like to see the conexions drawing in action!:cool:
Unread post by bsork » 03 Sep 2010, 18:08
NIce work a always!
(...and I really appreciate the attention to simple details with the new math modules.)
Unread post by woodslanding » 04 Sep 2010, 08:14
Where is this?? I can't find it.... will be great!
Unread post by nay-seven » 04 Sep 2010, 09:55
@woodslanding : IB / edit layout / re-organize
Unread post by woodslanding » 04 Sep 2010, 23:17
oh, that's no use to me. It reorganizes!! All my layout is destroyed!
I just want it to go to fullscreen.....
