Usine 4.22f
- senso
Usine [4.22f]
Must be downloaded to replace the 4.22e
fixed bugs
- save problems in the "channel" parameter of the create midi module
[4.22e]
intermediate update. You can skip it if everything works on you system.
fixed bugs
- small bug in the channel parameter of the create midi module
- the grain sampler now works in “loop+next” sample
improvements
- the max number of VST parameters in now 1024
- small synchro problem with the Molar VST
- new "Midi Unpack" script.
fixed bugs
[4.22e]
fixed bugs
improvements
- nay-seven
Thanks for the fix !
multiphone
Thanks a lot.
super !!
did you get a chance to zero the inputs of audio input busses when they are disconnected?
If not, I suppose I will wait to upgrade....
- senso
this problem will be solved in the next major release.did you get a chance to zero the inputs of audio input busses when they are disconnected?
please, it's not really an argument for me! This kind of modification can take more than 3 days to be implemented securely: development, test, package, etc.If not, I suppose I will wait to upgrade....
Sometime modifications cost nothing : have 1024 VST parameters instead of 512 takes maximum 10 seconds. And others can take much more than appears, and yours needs a deep refoundation of the internal buses system.
So I must include it in a global development perspective, even if I loose an upgrade!
sorry-didn't mean to sound snippy!
You said it was an "easy fix" when I first brought it up..... I'll keep waiting.
--e
--e
