ArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2008-08-14T18:27:22+01:00https://brainmodular.org/forums/app.php/feed/topic/9712008-08-14T18:27:22+01:002008-08-14T18:27:22+01:00https://brainmodular.org/forums/viewtopic.php?t=971&p=5026#p5026Statistics: Posted by nay-seven — 14 Aug 2008, 19:27
2008-08-14T17:15:22+01:002008-08-14T17:15:22+01:00https://brainmodular.org/forums/viewtopic.php?t=971&p=5025#p5025 Now I wonder if I want to sync it to master, should I: 1) Insert MasterSync module 2) Connect it's cycle pos output to Piano Roll's sync input?
]]>2008-08-14T15:55:55+01:002008-08-14T15:55:55+01:00https://brainmodular.org/forums/viewtopic.php?t=971&p=5024#p5024 the seqmidi module is an old one , senso let it here for backward compatibility ...
Statistics: Posted by nay-seven — 14 Aug 2008, 16:55
]]>2008-08-14T15:21:24+01:002008-08-14T15:21:24+01:00https://brainmodular.org/forums/viewtopic.php?t=971&p=5022#p5022what about the piano roll module...? you have synchro and quantize record options and you can export midifiles when you have finished.....
Statistics: Posted by nay-seven — 14 Aug 2008, 16:21
]]>2008-08-14T15:15:31+01:002008-08-14T15:15:31+01:00https://brainmodular.org/forums/viewtopic.php?t=971&p=5021#p5021 I said I was going to practice
I want to build a MIDI looper in Usine. Something like the Multiplayer X5, but for MIDI. What would be the best way to do it?
Half the patch is just me using trial and error. Don't know how to sync it to the master tempo, so that when I'd press start it'd start to record and by pressing stop the loop length would be set. All this using quantize.
Also, how to get that MIDI out later for recording it in a VST host?
]]>BrainModularBrainModular Users Forum2008-08-14T18:27:22+01:00https://brainmodular.org/forums/app.php/feed/topic/9712008-08-14T18:27:22+01:002008-08-14T18:27:22+01:00https://brainmodular.org/forums/viewtopic.php?t=971&p=5026#p5026Statistics: Posted by nay-seven — 14 Aug 2008, 19:27
]]>2008-08-14T17:15:22+01:002008-08-14T17:15:22+01:00https://brainmodular.org/forums/viewtopic.php?t=971&p=5025#p5025 Now I wonder if I want to sync it to master, should I: 1) Insert MasterSync module 2) Connect it's cycle pos output to Piano Roll's sync input?
