ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2008-08-13T19:47:16+01:00 https://brainmodular.org/forums/app.php/feed/topic/943 2008-08-13T19:47:16+01:00 2008-08-13T19:47:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=943&p=5010#p5010 <![CDATA[Installing a new version and retaining setup settings]]> Statistics: Posted by bassfucker — 13 Aug 2008, 20:47
2008-08-12T20:50:28+01:00 2008-08-12T20:50:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=943&p=4998#p4998 <![CDATA[Installing a new version and retaining setup settings]]> Statistics: Posted by bassfucker — 12 Aug 2008, 21:50
2008-08-12T20:37:31+01:00 2008-08-12T20:37:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=943&p=4997#p4997 <![CDATA[Installing a new version and retaining setup settings]]> Statistics: Posted by senso — 12 Aug 2008, 21:37
2008-08-12T20:16:58+01:00 2008-08-12T20:16:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=943&p=4996#p4996 <![CDATA[Installing a new version and retaining setup settings]]> Statistics: Posted by bassfucker — 12 Aug 2008, 21:16
2008-08-12T18:34:16+01:00 2008-08-12T18:34:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=943&p=4992#p4992 <![CDATA[Installing a new version and retaining setup settings]]> there is no limitation in the free version except the number of tracks.
Statistics: Posted by senso — 12 Aug 2008, 19:34
2008-08-11T23:56:25+01:00 2008-08-11T23:56:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=943&p=4990#p4990 <![CDATA[Installing a new version and retaining setup settings]]> I just downloaded the programme ... awesome !!!!
But my problems with the setup settings is, that nothing happens, no window opens either in the vst nor in the standalone version.
Is this a Bug ?
Or is it a demo limitation - although I didn't read something like this
I have the latest version ...
Statistics: Posted by bassfucker — 12 Aug 2008, 00:56
2008-07-29T20:17:00+01:00 2008-07-29T20:17:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=943&p=4922#p4922 <![CDATA[Installing a new version and retaining setup settings]]> Statistics: Posted by Vincent — 29 Jul 2008, 21:17
2008-07-19T08:57:03+01:00 2008-07-19T08:57:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=943&p=4875#p4875 <![CDATA[Installing a new version and retaining setup settings]]> Statistics: Posted by senso — 19 Jul 2008, 09:57
2008-07-19T08:18:42+01:00 2008-07-19T08:18:42+01:00 https://brainmodular.org/forums/viewtopic.php?t=943&p=4872#p4872 <![CDATA[Installing a new version and retaining setup settings]]> Statistics: Posted by mn — 19 Jul 2008, 09:18
2008-07-19T07:34:19+01:00 2008-07-19T07:34:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=943&p=4871#p4871 <![CDATA[Installing a new version and retaining setup settings]]>
it´s possible to save the setup as a file. Look at the small setup window and click 'File'. That makes it a little easier to restore the old settings.
Statistics: Posted by Stefan — 19 Jul 2008, 08:34
2008-07-18T23:30:17+01:00 2008-07-18T23:30:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=943&p=4869#p4869 <![CDATA[Installing a new version and retaining setup settings]]>
In any case, for the most part that is fine, I have all my patches and workspaces on another drive. But I have to do at least two things every time I install a new version: select my audio driver, and set my VST folder and rescan plugins. Probably other things like set folder directories that I don't notice as I am able to navigate around in any case.
Is there something I am overlooking to make upgrading smoother? Is there an easy config/xml/txt file I can copy and replace to pick up where I left off? I realize selecting the audio driver is trivial, and the VST scan is surprisingly quick for 1900+ plugs (2-4 minutes?). I also realize the format of this config file may change release to release.
Can the user configurable things be encapsulated in some way that we don't lose them each install? Or am I doing it wrong?
Statistics: Posted by mn — 19 Jul 2008, 00:30
Is this a Bug ?
