2008-07-16T22:08:53+01:002008-07-16T22:08:53+01:00https://brainmodular.org/forums/viewtopic.php?t=937&p=4851#p4851check properties of the picture or let your mouse on the thumbails ( depends of your browser)
Statistics: Posted by nay-seven — 16 Jul 2008, 23:08
Sorry, but parfois I need to pas faire trop d'efforts intellectuels to gagner du time. And I know you are french...that's why. Also, I understand your démarche. Why don't you give them number? Or dates?
Sorry for english users..
Statistics: Posted by moody33 — 16 Jul 2008, 22:10
]]>2008-07-15T00:14:32+01:002008-07-15T00:14:32+01:00https://brainmodular.org/forums/viewtopic.php?t=937&p=4831#p4831 ( by respect for this forum i answer in English ) this is olds works , and when i 've made exhibition with , i did'nt want to influence people ,cause each personn see different things... that's the reason why they don't have names...
Statistics: Posted by nay-seven — 15 Jul 2008, 01:14
]]>2008-07-14T23:01:19+01:002008-07-14T23:01:19+01:00https://brainmodular.org/forums/viewtopic.php?t=937&p=4830#p4830 Je viens de voir tes toiles. J'aime beaucoup celles sur Isorel. Les autres aussi d'ailleurs, notamment la 4eme...Globalement, ça tend vers un art primitif contemporain ( si on devait mettre une étiquette ). Tu devrais leur donner des titres. Ca pourrait aider pour dire lesquels on aime ou pas.
Happy new year everybody.
Statistics: Posted by moody33 — 15 Jul 2008, 00:01
]]>2008-07-14T18:11:01+01:002008-07-14T18:11:01+01:00https://brainmodular.org/forums/viewtopic.php?t=937&p=4828#p4828Statistics: Posted by nay-seven — 14 Jul 2008, 19:11
]]>2008-07-14T18:08:04+01:002008-07-14T18:08:04+01:00https://brainmodular.org/forums/viewtopic.php?t=937&p=4827#p4827I'm sure you need it!
]]>2008-07-14T10:42:22+01:002008-07-14T10:42:22+01:00https://brainmodular.org/forums/viewtopic.php?t=937&p=4826#p4826 ...a novel generator?? No, but maybe a lyrics generator based on the names of banned e-mail domains?
]]>2008-07-14T10:07:21+01:002008-07-14T10:07:21+01:00https://brainmodular.org/forums/viewtopic.php?t=937&p=4824#p4824i first load the patch , then create the text file...now i've reload it , no more problems...no more errors message
Statistics: Posted by nay-seven — 14 Jul 2008, 11:07
]]>2008-07-14T10:05:05+01:002008-07-14T10:05:05+01:00https://brainmodular.org/forums/viewtopic.php?t=937&p=4823#p4823 Next step : a novel generator??
Statistics: Posted by moody33 — 14 Jul 2008, 11:05
]]>2008-07-14T10:04:14+01:002008-07-14T10:04:14+01:00https://brainmodular.org/forums/viewtopic.php?t=937&p=4822#p4822 but I have some comments
- sometime lines are repeated twice. - you can set the 'index' max value to something higher the 10? - for large lines the display fields can overlap each other (to avoid that double click on the 'text module' and set the edit window to the maximum width) - I think it's better to use 'separator & panel' module to display lines because it fits the width automatically?
]]>2008-07-14T01:10:29+01:002008-07-14T01:10:29+01:00https://brainmodular.org/forums/viewtopic.php?t=937&p=4819#p4819script error :could not call proc in 0
don't know if i need such a pat , but thanks anyway...
Statistics: Posted by nay-seven — 14 Jul 2008, 02:10
]]>2008-07-14T00:20:57+01:002008-07-14T00:20:57+01:00https://brainmodular.org/forums/viewtopic.php?t=937&p=4817#p4817 The number of lines, as well as the "current line", can easily be changed, as this is governed by a couple of constants within the script.
The text file should be as "clean" as possible, without formatting ro suchlike. Use Notepad or some other text editor to save it.
I've uploaded it into the add-ons under "others", and the name..?
]]>BrainModularBrainModular Users Forum2008-07-16T22:20:43+01:00https://brainmodular.org/forums/app.php/feed/topic/9372008-07-16T22:20:43+01:002008-07-16T22:20:43+01:00https://brainmodular.org/forums/viewtopic.php?t=937&p=4852#p4852Statistics: Posted by moody33 — 16 Jul 2008, 23:20
]]>2008-07-16T22:08:53+01:002008-07-16T22:08:53+01:00https://brainmodular.org/forums/viewtopic.php?t=937&p=4851#p4851check properties of the picture or let your mouse on the thumbails ( depends of your browser)
