ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2008-07-10T23:58:16+01:00 https://brainmodular.org/forums/app.php/feed/topic/926 2008-07-10T23:58:16+01:00 2008-07-10T23:58:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=926&p=4788#p4788 <![CDATA[One note triggering]]> Statistics: Posted by nay-seven — 11 Jul 2008, 00:58
2008-07-10T22:55:25+01:00 2008-07-10T22:55:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=926&p=4784#p4784 <![CDATA[One note triggering]]> Statistics: Posted by ethnix73 — 10 Jul 2008, 23:55
2008-07-10T22:33:02+01:00 2008-07-10T22:33:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=926&p=4781#p4781 <![CDATA[One note triggering]]> Statistics: Posted by bsork — 10 Jul 2008, 23:33
2008-07-10T21:12:19+01:00 2008-07-10T21:12:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=926&p=4776#p4776 <![CDATA[One note triggering]]> thanks
Statistics: Posted by senso — 10 Jul 2008, 22:12
2008-07-10T20:02:35+01:00 2008-07-10T20:02:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=926&p=4774#p4774 <![CDATA[One note triggering]]>
With this patch you can select wich sample or midi loop will be played each time you hit play ( or a drum pad for exemple). Both can be played at the same time.
You can choose to loop sample or midi file when you hit play, to play midi file in a one shot mode.
There is one normal sampler and four piano roll. They're synchronised through step sequencers. A help file, accessible through the interface, is provided.
This patch could be extended with more normal samplers, grain samplers and more piano roll if needed. Still need some more work...
In the Others section.
Statistics: Posted by ethnix73 — 10 Jul 2008, 21:02
