ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2008-05-13T17:16:04+01:00 https://brainmodular.org/forums/app.php/feed/topic/833 2008-05-13T17:16:04+01:00 2008-05-13T17:16:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=833&p=4355#p4355 <![CDATA[Joystick to Step Value]]>
thanks
Statistics: Posted by cmodica — 13 May 2008, 18:16
2008-05-13T13:45:19+01:00 2008-05-13T13:45:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=833&p=4353#p4353 <![CDATA[Joystick to Step Value]]>
XY.pos X1 -> A*B.A
A*B.out -> SetArrayVal.index
XY.pos Y1 -> SetArrayVal.value
SetArrayVal.array out -> Step.values
Step.values -> SetArrayVal.array in
Set the B value of A*B to the same as Step.num of steps (or create a fader connected to both). You don't need the Trunc, Usine will truncate any floating point down to integers where applicable anyway.
Statistics: Posted by bsork — 13 May 2008, 14:45
2008-05-13T09:09:58+01:00 2008-05-13T09:09:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=833&p=4351#p4351 <![CDATA[Joystick to Step Value]]>
But there is a new problem .... when i move the joystick the numbers of step move to 1 to 16 (of course)!!!! :( But i'd like a fixed numbers of step and draw the values with my joystick...
thank you
Statistics: Posted by cmodica — 13 May 2008, 10:09
2008-05-12T22:31:44+01:00 2008-05-12T22:31:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=833&p=4350#p4350 <![CDATA[Joystick to Step Value]]> Statistics: Posted by bsork — 12 May 2008, 23:31
2008-05-12T09:33:50+01:00 2008-05-12T09:33:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=833&p=4347#p4347 <![CDATA[Joystick to Step Value]]>
I made one but it is limited to 16 steps max. I think i need to use "array" module to extend the steps numbers but i i don't know how ....
The X value of the "X-Y pad" module give the step number, and the Y value give the step value.
You can download this patch here
It will be easy to understand.
thank you
Statistics: Posted by cmodica — 12 May 2008, 10:33
thanks
XY.pos X1 -> A*B.A
thank you
thank you
